Budget 514 Stroker
Old Dec 1, 2003 | 08:42 PM
durtydawg's Avatar
durtydawg
i recall that a few years ago lunati made a crank that gave you 512 inches by offset grinding the journals and using chevy rods to fit the new diameter. dunno if they're still available, though.
Old Sep 23, 2009 | 04:06 PM
jefftaylor1678's Avatar
jefftaylor1678
It’s important to know that the 514 stroker is the largest stroker that can be internally balanced. The factory ford crank is rated for over 600 hp and you can have the rod journals offset ground to 2.200 to make a 4.14 or 4.15 stroke for use with 6.700 or 6.800 BB Chevy rods depending on piston mfg. As mentioned in a previous post in order to make this an internal balance crank the counter weights would have to be balanced by drilling and inserting Mallory in its place (heavier denser metal). The bottom line is all this work cost money and you can pick up a 514 internal balance crank usually for less than it will cost to have the work done. One other note when you have an internal balance motor and remove the counter weight you have to replace it with the proper Ford spacer or buy an aftermarket model usually about 30 bucks or so. Forged pistons for this set up will be very expensive the cheapest you will find will be Probe SRS for about $500.00 a set through TMD. The very cheapest way to do this is to buy a complete rotating assembly and have it balanced.....then your done with the exception of block machine work. I hope this helps you.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Old Sep 29, 2009 | 09:56 PM
doug1222556's Avatar
doug1222556
Here's an Eagle internally balanced crank:Eagle 514 Stroker Crankshaft BB Ford 104604140 460:eBay Motors (item 200389318176 end time Oct-29-09 15:20:13 PDT). Here's a kit:Ford 514 Eagle Crank Stroker kit Rotating Assembly:eBay Motors (item 370267183576 end time Oct-08-09 16:12:59 PDT). And another one with free shipping and balancing for $140. more:BB FORD 460/514 STROKER CRANK RODS MAHLE PISTONS KIT:eBay Motors (item 370168476464 end time Sep-30-09 22:52:56 PDT).
And here you can chose from several different options:SCAT-BASED Engine Kit - Ford 501 Flat Top -3.0cc.
If you can find some cheap pistons you could put your own kit together and possibly save some cash. If you have to pay this for them:Probe Industries SRS Forged Pistons - Ford 514 Flat Top -3.0cc, then you might as well go kit. I'm dreaming about building a budget 460 stroker in the future, but haven't spent the time looking for pistons yet.
Bubba Jones
1978 - 1996 Big Bronco
212
Jun 27, 2016 04:15 PM
wcpc4
Aug 6, 2015 01:01 PM
SuperDuty93
Feb 24, 2014 07:04 PM
shadow_almanza
18
Jun 25, 2010 12:17 PM
plcdwg101
Aug 11, 2009 07:39 PM
