1990 7.3 not starting
Old Nov 29, 2023 | 05:26 PM
wahlturfcare's Avatar
wahlturfcare
1 have a 1990 7.3 idi that has sat for about 2years because the injector pump went out. I swapped it out with a used one that ran but could never get the truck to run so it was parked. And also installed new motorcraft glow plugs at the time.
I recently swapped out the mechanical pump as I was thinking it was weak and installed a faucet pump.
I Checked the glow plugs and they all are still good, glow plugs relay runs for 10seconds.
Have the tank drained(but and running the fuel from a 5gallon can for now).
The injectors are getting fuel with the pump running (cracked the line caps to bleed any air and fuel seeps out)
Charged up the batteries and did replace one battery.
But can only get the motor to crank and sometimes Huff alittle bit.
Any ideas on what could maybe make it start?
Old Nov 30, 2023 | 04:58 AM
tjc transport's Avatar
tjc transport
i ain't rite
how fast is it turning over? there are two short videos of good starter and bad starter up in the stickies. a bad or weak starter with one weak battery and one new battery is enough to keep an engine from starting if there is air in the fuel system.
Old Nov 30, 2023 | 07:05 AM
Olds64's Avatar
Olds64
^^^THIS^^^
You can try to "jump" your truck with another vehicle. Make sure the other vehicle is running when you're cranking your truck.
Old Nov 30, 2023 | 07:13 AM
wahlturfcare
It cranks over pretty quickly. And I forgot to mention that I put a new starter and solenoid on it a few years ago but didn't use it much since then.
SMDT LLC.
Apr 5, 2021 12:15 PM
89ford460wrecker
Oct 17, 2017 08:42 PM
blueeyedfordguy
General Diesel Discussion
May 4, 2010 09:48 PM
snap_on_tootls
Nov 19, 2005 09:17 PM
mooner
Oct 17, 2002 11:52 AM
