2000 excursion
Old Nov 28, 2023 | 09:43 AM
Tapper08's Avatar
Tapper08
1st Gear
2000 excursion
How do I determine if the relay or motor is bad when it comes to my front vent/fan not working?
Old Nov 28, 2023 | 06:15 PM
450kexcursion's Avatar
450kexcursion
100000 percent it is the blower motor resistor. It is like 19 bucks. Mine just went out for the 90000000 time. So stupid really. The ford part from the factory lasted 380k miles. I have seriously put 4 in the last 70k miles. Takes longer to pop the hood then to change it out.
Old Nov 29, 2023 | 07:02 PM
DrPepper 2's Avatar
DrPepper 2
Exactly what 450kexcursion said, mine lasted around 330k and just had to replace the blower motor resistor last summer.
Old Dec 1, 2023 | 11:38 AM
05ExcurBros's Avatar
05ExcurBros
Mine is also do to be changed.
Old Dec 2, 2023 | 05:02 AM
MARCSPSD's Avatar
MARCSPSD
2001 PSD EX
My front blower motor works on position 1, 2,and 4.
When I use fan position 3 it blows the same as position 2.
Is this due to:
1. need new blower motor
2. need new resistor
3. need new fan switch
Thanking you in advance for your reply.
I am guessing that I need a new fan switch, but not sure.
Old Dec 2, 2023 | 05:39 AM
01__Excursion's Avatar
01__Excursion
The resistors are pretty stout, the biggest failure point is the plug connection to the resistor. I'd check that to see if all spade terminals are clean and free of corrosion and pitting. If the plug is really difficult to unplug from the resistor, than there may be corrosion.
https://www.ford-trucks.com/forums/1...-resistor.html
RPM Chris
Apr 12, 2010 11:02 AM
