302efi to a 351w efi. simple ques.
Originally posted by jwtaylor
yes computer and all, you have to modfy the fuel rail (should you reuse it) but given the 351 is complete otherwise, that is about it. YOu also need to use the 302 specific flexplate/flywheel. later
-Matthew
I think you would be correct. Thanks mathewP, hopefully fully_loaded reads this after the correction and not before. Yeah 302 uses a 50 oz flywheel/flexplate after 1982 and 28 oz before 1982 and the 351 used a 28 oz all the time. So yeah you need the 351 or 28 oz flywheel/flexplate or you will have one annoying vibration. Later
Actually all you need to do is keep the firing order specific to the engine. If it is a non HO 302 use 1-5-4-2-6-3-7-8 If the motor is HO 302 or a 351 use 1-3-7-2-6-5-4-8. YOu might run into more issues if you where converting a mass air or something but batch fire (speed density) to batch fire you should be fine keeping the firing order specific. Seems to work for everyone else. Good luck with your project
