DS2 short
Old Nov 24, 2023 | 08:56 PM
Dcurre1's Avatar
Dcurre1
DS2 short
Hey guys I was working replacing my lifters and think I may have damaged the old wring harness in my wheel well because now I’m not getting the truck to start and the dizzy is sparking when it touches the block or any other metal. Think it’s a short in the system somewhere but can’t be sure. Maybe it’s weakening my spark? Or is this normal? Thanks for the tips been busting *** all day just to have this issue arise when trying to start her up.
Old Nov 24, 2023 | 09:03 PM
Franklin2's Avatar
Franklin2
The distributor must touch the block, it's a important ground in the ignition system. If you have the key on, it will most likely spark. If the key is off, then you have something going on there. I would unplug the plugs to the module and see if it stops, and or unplug the connector on the coil and see if it stops. You should not have power at either place with the key off.
Spidermanmike
Apr 2, 2017 10:27 AM
f1504x4driver
Jan 25, 2017 08:35 PM
randy89
Jun 28, 2015 10:12 AM
Garden Spyder
Kansas Chapter
94
Nov 11, 2013 07:34 PM
justinyaa420
19
Jul 3, 2010 01:04 AM
