Vin Confusion
Old Nov 22, 2023 | 08:15 PM
Jacks66's Avatar
Jacks66
Trailering
Vin Confusion
Hello, I have a 1966 4x4, VIN code says F26 and 120 inch wheelbase. I have been looking for a bed and just to be sure, measure today and got 132 inches on the wheelbase, same as a F350......Is this common for the door vin and actual dimensions not match?
Old Nov 22, 2023 | 08:19 PM
85e150's Avatar
85e150
Welcome to FTE!
If the door was changed and they brought the donor warranty tag along, then you'll get the wrong VIN, dimensions, equipment etc.
Is the VIN on the title the same as the door tag?
Have you found the VIN on the frame?
https://www.fordification.com/tech/v...20frame%20rail.
Old Nov 22, 2023 | 08:21 PM
Jacks66's Avatar
Jacks66
Trailering
Thank you. yes, the door and the title match exactly. I am checking the frame next!
Old Nov 22, 2023 | 08:38 PM
Jacks66's Avatar
Jacks66
Trailering
Just checked, the VIN on the frame is same as the door. We did some more looking and appears somebody added 12 inches to the frame, just ironic it came out to 132, same as F350. Whomever did it, did a good job! Now we know, probably why it had a flat bed on it.
Old Nov 23, 2023 | 01:34 PM
BarnieTrk's Avatar
BarnieTrk
Jacks66 - welcome aboard, Chap!
Sounds like the flat bed came off of or was intended to be installed onto a F350.
Does it appear that the previous owner installed a F350 driveshaft too?
BarnieTrk
Old Nov 23, 2023 | 06:10 PM
Jacks66's Avatar
Jacks66
Trailering
It came from a farm in Montana, not sure if a stock driveshaft or not. If we can find a decent bed, will take the 12 inches back out, or leave as is and build a flat bed.
Old Nov 25, 2023 | 10:47 AM
James_Western_Canada's Avatar
Or you could find an F350 nine foot Wrongbed, which theoretically should fit.
If your back of cab to rear axle centerline measurement matches the dimension in the link below, the nine foot box should fit....
https://www.fordification.com/librar...94/category/72
**Sadly, I blew up that drawing, and the resolution is waaaay too low, cannot read the dimensions......
**Pic @ very bottom shows an F350 with nine foot bed
Old Nov 25, 2023 | 11:04 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Looks like 60”.
Old Nov 25, 2023 | 11:13 AM
Thank you Chad !
F250gizmo
May 6, 2017 12:28 PM
66Ford my baby
Sep 30, 2006 06:42 PM
thanaka
Jun 10, 2006 04:39 AM
pilotes
Oct 12, 2004 10:30 PM
bomberboat
Oct 7, 2004 05:41 PM
