Headlight Leveling Help
Old Nov 22, 2023 | 11:22 AM
Skid_Mark's Avatar
Skid_Mark
4th Gear
Hello,
When I load my camper I get a good amount of squat that aims the headlights sky high. Unloaded the level seems good. The owners manual states that the headlights are self leveling but this does not seem to be the case.
My truck is a 2023 f250 XLT with the sport appearance package so it has the LED reflector headlights.
lights. I do not have the load scales or the height sensors on the axles. There is a white plastic screw head behind each headlight which looks like a level adjustment but it doesn't want to move and I feel like I am going to break it.
Can someone enlighten me if these are actually self leveling somehow or the proper way to level these?
Old Nov 22, 2023 | 11:35 AM
4wd6.7L's Avatar
4wd6.7L
Well XLT certainly does not have the self leveling headlights, that requires Platinum or Limited trim. If you do decide to adjust the headlights be careful, they have been known to strip out or break sometimes on the previous gen. I would have to read the '23 OM, past owners manuals included headlight adjustment procedures.
Looks to be under the maintenance section of the OM "Adjusting the Headlamps".
Old Nov 22, 2023 | 11:39 AM
morehouse7's Avatar
morehouse7
They are a plastic gear mechanism and do not force them at all. I spray a teflon lube down into the gears if I need to move them and they move with ease almost no resistance. Many people have broken them.
Old Nov 22, 2023 | 12:09 PM
Skid_Mark's Avatar
Skid_Mark
4th Gear
Looking at the Owners Manual through the truck and also online there is no instructions, it just states that is has dynamic leveling and no adjustment is necessary. Maybe I will take it to the dealer and have them adjust it incase those strip out.
Old Nov 22, 2023 | 12:15 PM
morehouse7's Avatar
morehouse7
Ford and their documentation is consistently terrible
Old Nov 22, 2023 | 12:18 PM
4wd6.7L's Avatar
4wd6.7L
https://www.fordservicecontent.com/F...&buildtype=web
Adjustment procedure from the above online OM
Old Nov 22, 2023 | 12:27 PM
Skid_Mark's Avatar
Skid_Mark
4th Gear
https://www.fordservicecontent.com/F...&buildtype=web[/QUOTE]
Ahh Ok I was looking in the exterior lighting section. I will try some teflon spray.
Old Nov 22, 2023 | 01:21 PM
WXboy's Avatar
WXboy
Let me give you some advice. DO NOT use a Philips screwdriver on those adjustment screws. Use the correct Allen socket instead. Usually they are 6mm I think. Far less likely to strip them out.
Old Nov 22, 2023 | 01:27 PM
djousma's Avatar
djousma
Would it make more sense to fix the squat instead? Otherwise if you are unloaded your headlights will be too low
Old Nov 23, 2023 | 12:13 AM
Skid_Mark's Avatar
Skid_Mark
4th Gear
Yeah I added a set of sumo springs to help and I will be adding upper stabil loads to engage the overload springs sooner. I do want some amount of squat though when loaded. I do not like the idea of adding air bags and eliminating squat all together because then the airbags are point loading the frame and not letting the springs carry the load as designed.
KJCC
Apr 16, 2021 06:59 AM
Air Cooled Nut
Jan 5, 2020 03:46 PM
hjsimpson
Sep 1, 2010 02:36 PM
peterbilttrucker
Appearance & Dress-Up
Mar 9, 2009 10:21 PM
7.3 Rocket
13
Jan 4, 2009 09:44 PM
