Sponsored by: Real Truck
Sudden Power loss
Old Nov 22, 2023 | 02:16 AM
Manillagorilla's Avatar
Manillagorilla
2nd Gear
Sudden Power loss
Ok so 2010 f350 v10 cruising right down the highway at 80mph for about 45 min then falls on its face can’t go over 30 lightly floating the petal barely like 1/8” pedal movement any more back on its face. Codes thrown were for fuel rail pressure sensor and random cylinder misfire. Recent new filter since then still the same issue. Unplugged the rail sensor. Can get up to 60-70 gently on the pedal till it randomly face down till about 30mpg or so if I shut it off then restart lasts about 15 min as long as no up hill or back on it face. Codes thrown for fuel rail being in plugged but no more misfire but not much throttle power since the rail sensor not sending proper mixture to the injectors. Been this way for 4 days now had to think it’s the fuel pump in my past experience they usually don’t give that kinda warning they just stop. Not sure if has that teabag filter in the pump could be clogged ? Or the rail sesor faulty any thoughts
Old Nov 22, 2023 | 09:47 AM
Mike1's Avatar
Mike1
Did you check the fuel pump Pressure? That's where I would start. From there you should be able to determine if it's the pump or the pressure sensor, perhaps a bad wire or loose connector?
jj1221
3.0L Powerstroke Diesel
Aug 23, 2023 01:16 PM
92f1500
Jun 12, 2017 07:31 AM
BBoy
Modular V10 (6.8l)
Dec 26, 2011 06:54 PM
takimno1
Nov 2, 2005 03:04 PM
FTK560
4 Cylinder Engines
Mar 28, 2005 01:35 PM
