Flooding issue
Old Jun 11, 2017 | 07:54 PM
92f1500's Avatar
92f1500
Flooding issue
Hi everyone I'm new here an Im not sure if I'm posting in the right place or not but I have a 92 f150 with a 302 an I can't get it to start unless I put the accelerator to the floor an even then is runs terrible an I'll slowly let off of the pedal an it will die I've replaced the tps fuel pressure regulator an fuel filter an both fuel pumps an it holds good fuel pressure I'm at the end of my rope with this any help would be greatly appreciated thanks in advance
Old Jun 11, 2017 | 09:58 PM
88n94's Avatar
88n94
You could try replacing the MAP sensor. If you unplug the MAP sensor on a good running vehicle, you will get a rich condition.
NOTE: The suggestion to replace the MAP sensor is purely a guess on my part.
Old Jun 11, 2017 | 11:24 PM
joey2fords's Avatar
joey2fords
this would be a good time to a) pull codes, and b) advise what fuel pressure you are reading.
Old Jun 12, 2017 | 07:31 AM
'89F2urd's Avatar
'89F2urd
Yes, codes and fuel pressure. The pressure in the rail shouldn't drop when the pump stops running, so if it does then you know you have leaky injector(s).
Bradfsd
Nov 12, 2018 02:31 PM
Jkhuge
2004 - 2008 F150
Sep 28, 2017 03:12 PM
HulkMJW
Nov 6, 2006 08:46 PM
darthcasp
Aug 3, 2005 07:17 AM
harmdogg1978
May 14, 2005 12:09 PM
