Rotational Pinion play
Old Nov 20, 2023 | 06:26 PM
jacky Chan's Avatar
jacky Chan
Trailering
1983 Ford F150 4x4 Dana 44
when checking backlash in my front differential I’ve noticed that the pinion gear is spinning freely before catching and creating backlash.
Is this play suppose to be there?
I was thinking the pinion gear was warm and just has a little play does this seem like it could hold water?
I also know that when I put the truck in reverse and only in reverse it will make a clunk noise. I’m pretty sure it’s not a u joint problem or a rear differential problem.
Old Nov 20, 2023 | 09:05 PM
FuzzFace2's Avatar
FuzzFace2
Are you talking the front axle or the rear axle?
Maybe both?
I ask because I think the Dana 44 is a front axle and your rear I think a 9".
You also did not tell us how much play either one has and we cant guess from couches.
You will most likely have more back lash in the front axle as it will take a fine touch to feel the play between the pinion & ring gears before the axle shafts start to turn and take up play in the hubs and why more play.
The rear should have less but again we dont know how much back lash you have.
You can look up what back lash should be in the factory service manual.
Dave ----
Old Nov 20, 2023 | 09:31 PM
kr98664's Avatar
kr98664
we cant guess from couches…
Once again, I must disagree with your statement. I am fully able to guess from my couch.
Now had you said “we can’t guess accurately from couches” I would be in full agreement with you. But as written? Sorry, no.
Old Nov 20, 2023 | 09:39 PM
jacky Chan's Avatar
jacky Chan
Trailering
Maybe both?
Dave ----
my front differential as stated above and any amount of play
Old Nov 21, 2023 | 06:17 AM
FuzzFace2's Avatar
FuzzFace2
Well I should have said I was at "my" limit and yes added "accurately" would have covered everyone LOL
Dave ----
Old Nov 21, 2023 | 07:05 AM
FuzzFace2's Avatar
FuzzFace2
When you said when putting it in revirse it banged happens more for the rear not the front and why I asked.
Again you need to see if the play is the R&P or a combo of R&P and the hubs.
But in either case I dont think I would worry all that much with the front if the Ujoints, drive shaft & axles, are all good as you are not using the front in 4x4 mode all that much and even less forward and back to move.
I had a full size SUV 4x4 that I did a gear swap, dont remember why now but the front pinion nut could not go to tight and when in 4x4 mode on the high way you could feel it vibrate. I have driven it from L.I. to CT in a blinding snow storm and from CT to VT pulling a trailer with 4 snow moblies again blinding snow storm in 4x4 and a bunch in CT so its not like it was never in 4x4 on the high way.
I can tell you I never had any problems with it. BTW the gear swap was at 12K when the posi unit let go and I sold the truck with 238K
Dave ----
Old Nov 21, 2023 | 10:46 AM
Max Capacity's Avatar
Max Capacity
You said, "I also know that when I put the truck in reverse and only in reverse it will make a clunk noise. I’m pretty sure it’s not a u joint problem or a rear differential problem."
I'm old school, Anytime a car I had made that clunk noise when putting in reverse, it was a bad U joint.
How/why are you "pretty sure" it's not a bad U joint ?
"does this seem like it could hold water?"
Also, I'm no expert, but I don't think these parts will do well holding water. LOL
Old Nov 21, 2023 | 11:03 AM
FuzzFace2's Avatar
FuzzFace2
I did see the pretty sure too and that to me is not 100% sure they are good
Time to get under and check ALL of them.
Dont forget the front axle joints at the wheels
Dave ----
Old Nov 21, 2023 | 02:53 PM
jacky Chan's Avatar
jacky Chan
Trailering
Resolved
Dave ----
all u joints have already been replaced and the rear diff rebuilt. Play was excessive.
thanks for all the advice
Old Nov 21, 2023 | 02:59 PM
Franklin2's Avatar
Franklin2
When turning the driveshaft, look at the pass side axle. It has a splined joint in the axle and if it hasn't had any grease in while, they will wear and cause a lot of play. And when the going gets tough they will skip over the splines.
74F250390
Apr 10, 2009 04:35 PM
smallblock351w
Jun 10, 2006 09:51 PM
restoringmy46
Jan 8, 2005 10:37 PM
quadzjr
Offroad & 4x4
Nov 26, 2003 11:46 PM
butchf250
Oct 12, 2003 09:48 PM
