dana 44
Old Jun 8, 2006 | 09:42 PM
smallblock351w's Avatar
smallblock351w
dana 44
how do i know if i have a reverse rotation?
Old Jun 9, 2006 | 10:55 AM
averagef250's Avatar
averagef250
Reverse rotation is a bad term invented by ignorant people. The pinion is above the centerline line of the axle and the pinion will be on the driver's side of the ring gear. The commonly accepted term is "high pinion"
Old Jun 9, 2006 | 01:57 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Don't some call it reverse cut also?
Old Jun 9, 2006 | 05:01 PM
smallblock351w
Sorry to sound ignorant then hehe My parents own an auto repair shop and this change is for my personal truck. I just wasnt sure if it was a reverse cut gear or high pinion as you say. i spent last night reading up on it. And the reason i didnt really know is because we dont change that many gears really, specialy not in dana 44s. most dont bother with ratio changes only fix it if it breaks hehe anyways ordered my new gears today, 4.11 for the back and 4.09 for the front, cant wait to change them
Old Jun 9, 2006 | 07:51 PM
1bad73bronco's Avatar
1bad73bronco
If the axle is under a 71-77 bronco then most likely it is a low pinion and is standard rotation. If the axle is from under a f-100, f-150, bronco, etc, then it is high pinion and is reverse rotation... oops i said it, im ignorant
Old Jun 9, 2006 | 07:56 PM
smallblock351w
hehe, and its under a 1980 ford f 150
Old Jun 9, 2006 | 08:05 PM
1bad73bronco
10-4 its a 30 spline high pinion Dana 44
Old Jun 9, 2006 | 08:06 PM
1bad73bronco
reverse rotation
Old Jun 10, 2006 | 04:21 PM
F150xlt's Avatar
F150xlt
You may want to verify this information taken from a Helms Service manual. I'm assuming you have a Dana 44 IFS.
When changing ratios on the 44 Series front drive axle, it may be necessary to change the differential case along with the ring gear and drive pinion.
Ratios 2.72 to 1 and up to 3.73 to 1 incorporate a thick differential case flange and a thin ring gear. Ratios 3.92 to 1 up to 4.09 to 1 incorporate a thin differential case flange and a thick ring gear.
Old Jun 10, 2006 | 06:07 PM
smallblock351w
actualy when i ordered the gears they said i had to change carriers, that after 3.73 to go to a lower gear it was different, so ordered a new carrier to
Old Jun 10, 2006 | 09:00 PM
1bad73bronco
I believe a 80 F-150 has a straight axle dont it smallblock351w?
Old Jun 10, 2006 | 09:51 PM
smallblock351w
no it has the independant style that they used, not the straight axle. think this is the year that they switched to it? not sure though
