Able to remove modules with forscan?
Old Nov 18, 2023 | 10:50 PM
flatblk's Avatar
flatblk
4th Gear
Wondering if anyone knows if I would be able to remove modules from truck with forscan? I basically made a stand-alone harness for a 2019 f-250 6.7 powerstroke engine, trans, transfer case module, body control module and communication module. I’m putting a 1971 body on this chassis and want to get rid of my lost communication codes with modules I removed. Just wondering if anyone on here know if it’s possible or even better how to do it. Thanks
Old Jan 21, 2025 | 01:33 PM
Mr ferny's Avatar
Mr ferny
1st Gear
Any solutions?
We're you able to find a solution? I'm attempting to do something similar where I'm basically keeping a simple hardness and delete some modules for a frame swap I'm doing from a 01 ford explorer onto a 68 Ford pickup.
Appreciate your reply.
Old Jan 21, 2025 | 06:02 PM
number9xd's Avatar
number9xd
My guess would be - maybe?
I am pretty sure I’ve seen where the TCU can be noted as present or not, same with the network it talks on (forget the name).
Note - I am not a Forscan guru by any means, maybe one of those guys will respond.
flhtci2006
May 10, 2020 09:25 AM
rattlehead
Dec 18, 2007 04:58 PM
threespeed
Bronco II
Mar 4, 2005 11:23 PM
QuangBroncoII
Bronco II
Feb 22, 2004 12:01 AM
