Door lock help
Old Nov 16, 2023 | 02:32 PM
robbyrob1992$'s Avatar
robbyrob1992$
5th Gear
Door lock help
Lock works but no unlock keyless entry just clicks switch has power and shorts to ground when activated but only click noises
Old Nov 16, 2023 | 02:56 PM
My4Fordtrucks's Avatar
My4Fordtrucks
One door or both do this? What vehicle?
Old Nov 16, 2023 | 07:07 PM
robbyrob1992$
5th Gear
Re
1997 f350 both lock switches lock all 4 doors and both unlock button makes keyless entry click under dash
Old Nov 16, 2023 | 11:42 PM
TexasGuy001's Avatar
TexasGuy001
Is this factory or aftermarket keyless entry or alarm setup?
Old Nov 17, 2023 | 03:11 AM
robbyrob1992$
5th Gear
Re
Factory keyless entry in obs f350 xlt … I tried checking the pink and black wire and pink and orange wire coming out of keyless but don’t get any volts … maybe I’m doing something wrong but neither one is hot at resting position when I push the lock botton one goes hot when I push unlock both go hot 🤯🤓🤔🧐🧐
Old Nov 18, 2023 | 10:31 AM
dremtofford's Avatar
dremtofford
the relays are bad. and check the ground.
Old Nov 21, 2023 | 05:50 AM
robbyrob1992$
5th Gear
Re
the relays are bad ?? The only relay I could find was in the keyless entry module itself … I can check for ground in the morning
FordLou
1997 - 2003 F150
22
Sep 28, 2016 11:37 PM
hein8808
Jul 1, 2010 01:55 AM
98f150iowa
1997 - 2003 F150
Jan 24, 2008 05:27 PM
Rangerman255
1983 - 2012 Ranger & B-Series
Jan 9, 2005 03:17 PM
