door locks
Old Jun 2, 2010 | 08:18 AM
hein8808's Avatar
hein8808
door locks
My 2005 excursion will not unlock from any of the door lock switches but the lock works. also the unlock and lock works from the remote and the keyless entry. i replaced both front actuators.and tested the switches there is power to the lock wire(red/white) but no power to the unlock wire(black/white). does anyone have any other suggestions?
Thank you.
Old Jun 30, 2010 | 10:04 PM
shortbusted's Avatar
shortbusted
Did you find an answer? I have a similar problem.
Old Jul 1, 2010 | 01:55 AM
mark996's Avatar
mark996
Would a bad switch cause it to not get any power to that black side? Have you tried replacing the switch, or see if you can find someone with a ford that will let you use one of their switches to check it? I'd almost say wiring issue but with both switches, I don't know.
detill
Aug 29, 2013 06:23 AM
Backin72
Jun 1, 2008 04:14 PM
Boose
Jul 1, 2004 09:40 PM
K2JJB
Electrical Systems/Wiring
Jun 15, 2004 11:05 PM
