Where is the Mass Air Flow sensor on 94--302 - Ford Truck Enthusiasts Forums
Old 03-30-2004, 08:44 PM
adrianlovessnow
adrianlovessnow is offline
adrianlovessnow is starting off with a positive reputation.
I have a 94 302 5 speed 4x4 I would like to know where the MAF is located. A buddy of mine told me that is why i am getting poor milage 8mpg. Is that true? I have changed 02 sensor, plugs cap rotor, engine temp sensor the one that goes to comuter. Please help me. The inside of the tail pipe looks like a desiel.
Thanks in advance,
Adrian
Old 03-30-2004, 09:00 PM
LoosMaster's Avatar
LoosMaster
LoosMaster is offline
LoosMaster is starting off with a positive reputation.
Been awhile since I seen a new model but my '96 was just after the filter box. Square with a connetor attached to it.
Old 03-30-2004, 09:05 PM
boulderbronco
boulderbronco is offline
boulderbronco is starting off with a positive reputation.
Thats where it is. But I doubt thats your issue. You would get a check engine light if the sensor was bad. Have you checked your fuel pressure? It's possibly your pressure regulator. Have your pressure checked.
Old 03-30-2004, 09:08 PM
ranger88a
ranger88a is offline
ranger88a is starting off with a positive reputation.
Not really, I almost never get a code for the maf sensor. It may be dirty and contaminated and will never set a code, but will give you fits on driveability problems. Including fuel mileage!
Old 03-30-2004, 10:22 PM
adrianlovessnow
That is where I thought it is but it isnt there??? It goes from the filter box to the tubes that go to the throttle body??? It isnt throwing any codes?? Fuel pressure is good with new regulator.
Old 03-30-2004, 10:27 PM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
If it's not there, then you don't have a MAF equipped truck. The problem is elsewhere. Try pulling the codes and see what you come up with.
Old 03-30-2004, 10:30 PM
adrianlovessnow
The Ford dealer said their are no codes??? I dont know I am clueless
Old 03-30-2004, 10:32 PM
EPNCSU2006's Avatar
EPNCSU2006
You can check for yourself - go to http://fordfuelinjection.com and click on "Getting Codes" to find out how. Check the fuel pressure regulator to see if it is working properly, and also test fuel pressure to see where it is running.
Old 03-30-2004, 10:37 PM
adrianlovessnow
I will check for codes this weekend? any other suggestions. It has new fuel regulator and pressure is good.
Old 03-30-2004, 10:43 PM
EPNCSU2006's Avatar
EPNCSU2006
Next thing I would do would be to test the MAP sensor and the injectors, and the related wiring. There could be an injector sticking open and flooding things out. How do the plugs look?
Old 03-31-2004, 12:46 PM
adrianlovessnow
The plugs looked good they were a light brown color.
Thanks I appriciate your comments. I am learning and it is helping.
Old 03-31-2004, 12:58 PM
adrianlovessnow
Could be the MAP
The problem may be the MAP? any thoughts on that? How should I test it??
Old 03-31-2004, 04:54 PM
EPNCSU2006's Avatar
EPNCSU2006
Have you checked the timing recently? Retarded timing can cause poor economy and poor performance. A Haynes manual will have the procedure for testing the MAP sensor. It tells you that with the key on, engine off (no vacuum) that the MAP signal wire should show 5V, which is incorrect. The orange wire (VREF) should have 5V, but the blue wire (MAP signal wire) should have 2.5V on it with the sensor plugged in.
Old 04-07-2004, 09:52 AM
adrianlovessnow
finaly got codes
I finally checked for codes and got a code 133 koeo. I have no clue what that is does any body know?
Thanks
Old 04-08-2004, 12:10 AM
EPNCSU2006's Avatar
EPNCSU2006
I don't think a 133 is possible. http://fordfuelinjection.com/codes
Quick Reply: Where is the Mass Air Flow sensor on 94--302
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
