1964 steering drag link
Ford Pickup Truck Drag Link Or Center Link - F100 With Manual Steering | Classic Truck
Is it longer if it is 4x4?
First link above is for the more common standard 3,000 pound 4x4 front driving axle as well as many of the 2WD trucks other than the twin I-beam.
C1TT-3304-M - 1961/64 F100/250 2WD with manual steering & 4WD with 3,000 lbs. capacity front driving axle // 1965 F100 4WD // 1965/66 F250 4WD with 3,000 lbs. capacity front driving axle.
Second link is for the less common optional 3,500 pound 4x4 front driving axle and F350.
C1TT-3304-AH - 1961/66 F250 4WD with 3,500 lbs. capacity front driving axle & F350
Drag link
I bought the one to put on my 64 F350. I winched at the price, but I could not find a OEM any place. It turned out to be a heaver replacement than the stock piece. It fit right on and no problems with it. Only gripe is the placement of the grease fitting. It's on the opisite side of the bar and is awkward to grease. Other than that, it works like the OEM.
AggieOutlaw
03-22-2012 07:50 PM
mikem78
01-05-2004 11:10 PM
