Electric fuel pump not working
Old Nov 10, 2023 | 11:33 PM
Jebster's Avatar
Jebster
4wd High
Hi y’all,
my 1978 F100 (RHD) will not start and I’m pretty sure it’s the fuel pump, because it isn’t making any noise when I try to start it. Is there any way for me to tell if the problem is wiring or the actual fuel pump? I’ve never really done any wiring before so I have no idea where to start. I don’t have a voltage or amp meter.
This is the fuel pump. The black wire is a ground and the red keeps on going
This is where I lost the red wire (it turned white). How do I follow it past this? It went up through this hole which is under the back of the cab.
Old Nov 11, 2023 | 07:25 AM
73FOMO's Avatar
73FOMO
Follow in the interior …most likely going to under dash/ignition area, but I would get a cheap test light or multimeter and check red wire and ground, but also check the black wire to make sure it is grounded good.
Old Nov 11, 2023 | 07:36 AM
FuzzFace2's Avatar
FuzzFace2
Originally Posted by 73FOMO
Follow in the interior …most likely going to under dash/ignition area, but I would get a cheap test light or multimeter or both as you will use them down the road and check red wire and ground, but also check the black wire to make sure it is grounded good.
I made a change to the above answer.
Some testing it is easier to use the light like for this but if the truck or other cars you have dont charge the battery you need the meter.
HF has them cheap and will do the job for use once in a while.
Dave ----
Old Nov 11, 2023 | 09:49 AM
Viper Pilot's Avatar
Viper Pilot
Why don’t you have a multimeter? Basic tool if you’re working on your own stuff. Get one.
In the meantime, you could just supply 12V directly to the pump with a couple scraps of wire and see if it runs.
Old Nov 11, 2023 | 10:37 AM
tbear853's Avatar
tbear853
Originally Posted by Jebster
Hi y’all,
Start with getting a test light, bare minimum.
Andrea willis
Oct 20, 2023 07:39 AM
mecsey33
Feb 28, 2015 06:45 PM
Breaker Breaker 3-3
Jan 27, 2013 12:58 PM
capitanjo
19
Nov 29, 2011 04:50 PM
CrazyFazy
Bronco II
Dec 17, 2005 02:09 AM
