Bronco II Ford Bronco II
fuel pump wiring
Old Dec 11, 2005 | 08:47 AM
CrazyFazy's Avatar
CrazyFazy
fuel pump wiring
Does it matter if the wires going to the fuel pump get reversed? If my brother does got them wrong will the truck start but run like crap? This is on a 89 bronco 2 for my brother.
Old Dec 11, 2005 | 02:43 PM
Ken00's Avatar
Ken00
That may cause a problem if you switch the ground and hot wire.
Old Dec 11, 2005 | 07:47 PM
CrazyFazy's Avatar
CrazyFazy
I am wondering if it would still start though. It starts but runs like crap.
Old Dec 12, 2005 | 08:30 PM
Ken00's Avatar
Ken00
Since your using DC current I would Guess the pump would turn the wrong way and could effect the fuel pressure.
How did it run before replacing the pump?
Old Dec 13, 2005 | 03:15 PM
CrazyFazy's Avatar
CrazyFazy
It ran like crap but i think the problem then was bad wiring going to the relay. I guess i could pierce the wires and use a meter and see if it shows negative voltage. Just thought maybe someone would know if at least it would run. When i find out i will let yas know.
Old Dec 13, 2005 | 06:35 PM
87 XLT's Avatar
87 XLT
Screw on a fuel pressure gauge & check the pressure.
Old Dec 13, 2005 | 08:17 PM
Ken00's Avatar
Ken00
A meter won't help answer the question. Check the presure like 87 said.
Old Dec 17, 2005 | 02:09 AM
bronocIInoob's Avatar
bronocIInoob
revirsing the pump terminals would cuase the engine to run not at all i would think unless you have a 1889 tru 1986 bronoc i think those years had 2 pumps so one only may be working just enough to get veru low fuel presssure to make it run, but like crap ethier way check both pumps with your meter on the ohm setting and see if ethier have continutiy if one or both show no connection then say goodbye you would have a fried pump if they are fried id run some tests to see why they fried before putting a new one in
SuperDutyScaler
1997 - 2003 F150
Apr 5, 2015 01:30 PM
SDElwood
Michigan Chapter
May 26, 2011 09:27 AM
bucks77ford
General Automotive Discussion
Apr 17, 2011 12:12 AM
maxum96
Apr 5, 2010 11:20 PM
dh1031
401, 477, & 534 SD Engines
Oct 5, 2008 06:46 PM
