Pinion seal's leakin'
Old Nov 10, 2023 | 10:27 AM
RA101725's Avatar
RA101725
Banned
Comes up as a F5TZ-4676-A for a Dana 80 rear end. Cross references Dana-Spicer P/N 46411.
Replace the pinion nut too or is that re-usable?
Breather tube was partially blocked...need to be checking that every oil change I guess. Cleaned that out real good and cleaned the seepage up and thought maybe it had quit leaking for a day or two, but nope. Still leaking. 100k since the axle was rebuilt including all the seals and I am guessing they didn't use the OEM Motorcraft or Dana-Spicer replacement parts and it just got tired from all the heat cycles over the summer. Oil needs dumped anyway, it's been in there way too long. Got a lube-locker gasket ready to go...Banks is taking their sweet time with their Dana 80 cover or I'd be putting one of those on too. (Not out yet but maybe next time.)
Old Nov 10, 2023 | 01:46 PM
akcooper9's Avatar
akcooper9
I just installed this cover on my Dana 80 with a lube locker gasket (make sure the logo'd part of the gasket goes towards the differential). Pulled the skid steer down the highway for 30 minutes and then cover temp was 120 degrees when I stopped and measured it. Very happy
https://www.ebay.com/itm/374442767556
Old Nov 10, 2023 | 05:14 PM
RA101725's Avatar
RA101725
Banned
Already have one of those...just like the OEM one Ford put on the F-450 with the same axle. Already had a Lubelocker gasket as well but, long story on that one. The Banks covers look bad *** and come with it's own integrated gasket, but I think the biggest selling point is that the damn thing has a drain plug so you'd never have to take if off again for routine service. Sold. But it ain't available yet or he'd already have my money.
I don't think the shop manual says anything about discarding the big nut and I don't think this axle uses a crush sleeve either. I'll dig up the shop manual section and see what it says.
Old Nov 10, 2023 | 05:34 PM
Tpayne621's Avatar
Tpayne621
That banks cover with the scoops under the axle and fins and all internal oiling baffles and stuff is trick looking. Just a lot of money for a diff cover. 😂
Old Nov 10, 2023 | 05:57 PM
INFRNL's Avatar
INFRNL
I personally don't or wouldn't support Banks for my own personal reasons.
I also do not know that there is any benefit in an aftermarket diff cover.
However I do have a mag-hitech only because i like how it seals with an o-ring , has a drain plug as well as a way to check the fluid without taking the cover off.
If a person is buying because they think it helps keep temps cooler by having more capacity...that can go either way. Yes, it will take longer for the extra capacity to get up to temp but also takes twice as long to cool all the oil down. When I got my tranny rebuilt at BTS. I asked brian if it was beneficial to get an aftermarket pan. His answer was no for the reason I just mentioned.
With that said, oem diff covers/ pans; they have proven to be plenty sufficient as long as the owner keeps up on maintenance. Even with people that do not take proper care of things, they still do the job.
It's just a market that people fall for and I am guilty of this as well. Just my 2 cents
Kadin Cook
Apr 27, 2026 09:59 PM
clhart426
Dec 21, 2020 05:46 PM
farmnaggie
Mar 7, 2012 06:24 PM
F1004x4Owner
29
Nov 27, 2011 10:12 PM
