electrical issue
Old Nov 5, 2023 | 07:45 PM
cranegrad's Avatar
cranegrad
electrical issue
i have a 95 f250 5.8 that has just started to have electrical issues. when i turn the truck off i won't be able to start it again until it sits for a minute or two. everything goes dead--even the radio loses it's settings. i tried jiggling the key and checked the battery connections and they are fine. the alternator is charging the system according to the gauge. anything i should be checking? Thanks.
Old Nov 6, 2023 | 09:44 AM
jas88's Avatar
jas88
The radio memory does not go thru the ignition switch. I say you have a bad connection at or near the battery.
Old Nov 6, 2023 | 12:35 PM
cranegrad's Avatar
cranegrad
i had a parasitic draw (i thought) so i got one of those disconnects that go on the battery post. each time i used the truck after that my radio settings were gone because the unit was disconnected from 12V. i just used the radio to emphasize the fact that my truck goes totally dead as if i disconnected the battery. One thing i should add is that the last time i drove it i accidentally pulled back on the turn signal arm (as if i were flashing the brights) and needle on the amp guage was twitching. could the multifunction switch case the 12V supply to go dead? Thanks.
BassFantasizer
Jun 27, 2022 12:36 PM
flysniper
Jan 31, 2018 05:54 PM
OKeefe73
Oct 16, 2017 05:23 PM
slayer61
Sep 2, 2010 03:01 PM
fttahmas
Jun 12, 2004 10:14 PM
