'94+ Caliper Conversion
Old Nov 5, 2023 | 03:07 PM
BricknoseBo's Avatar
BricknoseBo
4wd High
I have a '91 F150 4WD with the old V groove style calipers that keeps sticking and chewing pads. Does anyone know if a '94+ 4WD knuckle with the floating Caliper design would fit? I imagine I'd beable to just swap knuckles and calipers but reuse my rotors/hubs? If anyone has done this before or has any knowledge of a thread that has I'd appreciate it.
Old Nov 6, 2023 | 07:15 AM
manicmechanic007's Avatar
manicmechanic007
I have not done it and do not know but think it would work
The ball joints and axle housings are the same I think, so, it should work
Old Nov 6, 2023 | 11:24 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I believe that would work. You could double check that the rotor part numbers are the same. In the almost 30 years of owning these trucks, I have never had that problem. What are you using to lubricate the caliper pins?
Old Nov 6, 2023 | 12:38 PM
R&RFord's Avatar
R&RFord
The later trucks also have different spindles, hubs and rotors.
Old Nov 7, 2023 | 11:08 AM
BricknoseBo
4wd High
I'm used Brake Caliper grease when I replaced the calipers/rotors/pads. A generous amount on both the knuckle, caliper, and slide pins. Only 1 pad, the outside right, likes to stick when the brakes get hot. I'm going to have to do balljoints soon so I figured I'd switch the knuckles/calipers over while I have it out. No downsides to the swap so why not.
Old Nov 7, 2023 | 11:14 AM
My4Fordtrucks
Could also be the hose holding pressure
mrese
Aug 15, 2021 07:52 PM
hink10
Jul 18, 2021 01:24 AM
Bootlegger's Deluxe
Jan 28, 2016 07:19 AM
cabloom300
Jul 19, 2013 09:38 AM
61 uni
May 16, 2009 07:53 PM
