Starter issues
Old Nov 3, 2023 | 04:18 PM
Mpotter213's Avatar
Mpotter213
2nd Gear
Starter issues
I have a 1988 F150XLT lariat. It's burned through 5 starters. I just put a new one in yesterday. And it stopped working again today. The starter works for a little bit. And then it will just spin in the mechanism. It's got a brand new solenoid and It's got a brand new alternator can anybody help me out?
Old Nov 3, 2023 | 05:00 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
From where are you acquiring the starters? Do you have a quality electrical shop locally?
Most of us upgrade to the PMGR starter found on the later trucks due to ease of install and better output.
Old Nov 3, 2023 | 05:01 PM
kenny nunez's Avatar
kenny nunez
Starter
It is an electrical problem. The starter is staying engaged after the engine starts.
Old Nov 3, 2023 | 05:54 PM
Soup bean's Avatar
Soup bean
Is your truck standard or automatic?
Are the fender mounted starter relays (solenoids) failing?
On my truck, the fender mounted starter relays kept welding themselves closed, causing the starter to run continuously. After several relays, and a couple of starters, I discovered that my problem was firewall flex, so the clutch interlock switch wasn't closing all the way, and wasn't making a good electrical connection. I shimmed the clutch interlock switch and the problem resolved.
It's possible that a bad connection at the fender mounted starter relay, a poor ground connection between the base of the relay and the fender, poor connections at the clutch interlock safety switch or neutral safety switch, could contribute to starter relay failure.
Old Nov 3, 2023 | 06:29 PM
Mpotter213's Avatar
Mpotter213
2nd Gear
Starter issue
I got it fixed the top bolt had come lose but I got the starters from oreillys
Old Nov 4, 2023 | 10:00 AM
1Butcher's Avatar
1Butcher
I bet it's those lifetime warranty starters. Yes, they have lifetime warranties but you better have the tools with you to replace them because you will be replacing those starters for a lifetime.
indebt
27
Oct 19, 2022 07:03 AM
DesertSmoker
Modular V10 (6.8l)
Apr 25, 2022 05:03 AM
airboater67
Apr 18, 2021 08:36 PM
867.309
May 14, 2019 01:19 PM
RumRunner78
Mar 30, 2014 06:42 AM
