Longer crankning after removing HPOP check valves?
#31
Gonna order the Melling pump.
Worth doing a damper while I'm in there?
#32
My damper went south and did pump while there.
The autozone $200.00 dampers were not good qualtiy and went through two of them in a few days of use. The rubber on one wasnt even cured. The other one the rubber didnt stick to the steel outer hub
I went with Fluid Damper which can never wear out but it does go for 600 and you need to keep a 10 mm wrench in glove box to take fan off for a belt change unless you get a SD pulley.
The following 2 users liked this post by knottyrope:
#34
The following users liked this post:
#36
#37
These 7.3 cant die easy if you run out of oil, unless going down a long grade
Why?
Once injection system gets a bubble of air, the injectors wont fire thus saving engine in a low oil condition.
IMO, stick with the OEM dash gauge that runs off a switch unless you like extra things to look at
Why?
#38
Why?
Why?
flatbedstroker
03-25-2009 06:23 AM
