1978 - 1996 Big Bronco
Need Help on this big time
Old Nov 21, 2003 | 09:23 PM
Demon345's Avatar
Demon345
Ok, right now i am a really mad kid, im 16, i got bronco back today from the shop where they put my pipes on and they did a great job. It was def. worth the 400 dollars for the custom setup......
Well anyway, I have a set of 35x14.50x15 Mickey Thompson Baja Belted HP in my backyard that I only bought them all for 200 bucks brand new (they were probably stolen), but my dad said that they are going on the truck because a 4 inch lift wont do the trick. But i said the 4in lift will be enough, suspension lift by the way, but he still didnt agree, so, i really want these tires on my truck because i really dont want to go smaller than that, so can you guys tell me if a 4in will do te trick, even if i gotta trim the fender a little, that will be ok, just tell me that will work
-Rich
Old Nov 21, 2003 | 09:43 PM
AYoungblood's Avatar
AYoungblood
Yes, from what ive read 35's with a 4in will work, be very tight and rub a lot but with some fender work they should be fine.
If you can look at about 1' more for a very equal medium. (if you get that)
Adam
Old Nov 21, 2003 | 09:48 PM
Demon345's Avatar
Demon345
Thanks, but I need more opinions here because my dad still doenst believe anyone until i get some people with the lift
Old Nov 22, 2003 | 01:16 AM
springer70's Avatar
springer70
35's with 4 inches of lift will work
Old Nov 22, 2003 | 11:18 AM
BillyBob69's Avatar
BillyBob69
My 87 started with stock and 31's. I added a 4 inch lift and slapped some 35's in there. I had a slight rubbing so I added a 1in body lift and all worked great. I considered trimming the fender but didnt feel like making that kind of mod. So long as your lift has all the parts needed to be done correctly, you should have no probs. Have fun with it and dad.........ITS HIS TRUCK! You can only learn by trying.
Old Nov 22, 2003 | 11:22 AM
dblue351's Avatar
dblue351
4 Inch rancho and 35 BFG's helped me for many years!
Old Nov 22, 2003 | 01:14 PM
iskybantilus's Avatar
iskybantilus
will definatly clear. we had an 88 with a 3 inch body lift and that cleared 35's ... only interference was front bumper needed to be pushed forwards. with suspension lift, you should be avoiding that problem. should fit and look awesome. just try convincing him a little more and a little better.
Old Nov 23, 2003 | 12:27 PM
steve83's Avatar
steve83
33's on stock rims will clear with NO lift and NO fender-trimming; just a 3/4" spacer behind the front bumper. 35's should clear easily with 3" and have NO problems at all with 4". Click my signature and look in the BroncoFest/BroncoBash photo album. There's a flex test on a lifted Bronco in it.
aperry619
New Member Introductions
Oct 14, 2016 08:27 AM
jjoyce11
2004 - 2008 F150
Jan 3, 2016 10:18 AM
SDSC4X4
Mar 23, 2015 06:38 PM
PowerstrokeJunkie
Mar 12, 2006 05:55 PM
Larry
Jan 21, 2000 09:23 PM
