c6 Pressure Issue
Old Nov 1, 2023 | 01:43 PM
Tbird9140's Avatar
Tbird9140
Trailering
Unhappy c6 Pressure Issue
I have a 1989 van with a c6 behind a 351W. The transmission is blowing trans fluid out the overflow tube when it is running. The transmission shifts fine. However even before it has had a chance to heat up if you drive it at any RPM it will blow fluid out the overflow. The blown out fluid is NOT hot and the dip stick does indicate that the level is correct when idling. When driving if you back off on the RPMs the overflow will stop or slow down. However when you again increase the RPMs the overflow will start up again. Same when going up a hill. Has anyone come across this problem???
Old Nov 2, 2023 | 06:27 AM
tjc transport's Avatar
tjc transport
i ain't rite
when i ran into that issue, it was always caused by a clogged vent.
Dayton wriedt
Oct 23, 2018 10:00 AM
big_ford_rednek
Feb 22, 2009 11:13 PM
sigtauenus
Nov 13, 2005 06:30 AM
76390FE
Dec 11, 2003 12:57 AM
