Cleaning rust on Diff. cover
Old Oct 31, 2023 | 06:56 PM
NSAJMART's Avatar
NSAJMART
How would you all clean the inside cover of my differential? Also, I've heard of putting a magnet on the inside cover to catch any loose metal. Is that legit? Thanks for any help!
Old Nov 1, 2023 | 05:21 AM
NSAJMART's Avatar
NSAJMART
I'm wondering if I couldn't sand it down to get it off, but would I have to shoot a primer on it to keep it from rusting again? The truck must have sat for a long time for it to rust like that.
Old Nov 2, 2023 | 11:00 AM
1Butcher's Avatar
1Butcher
Muriatic acid. Cement cleaner.
Read the warnings and except the risks.
I would not paint the inside of the cover. I would expect the paint to just flake off.
Old Nov 2, 2023 | 11:13 PM
xlt4wd90's Avatar
xlt4wd90
sand off the loose stuff and get some phosphoric acid to wash off the remaining surface rust. It's not as harsh as muriatic (aka hydrochloric) acid, which will dissolve the good metal along with the rust.
Old Nov 3, 2023 | 09:20 AM
1Butcher's Avatar
1Butcher
All the acids will dissolve the good metal along with the rust. Some are much faster. Within a minute or two, you'll be done with muriatic acid and have it installed before the phosphoric has even shown a difference.
Make certain you neutralize whatever you use when you are done.
Old Nov 8, 2023 | 07:40 PM
John89's Avatar
John89
If you are not in a hurry, check with your local HS shop teacher to see if he/they could use a blast cabinet (gently).
Or what the others have said. Or some vinegar.
I 2nd not using paint on the inside, the gear oil should keep it from rusting again as long as you keep the water out. I'd paint the outside.
Also skip the RTV and use a lube locker gasket on install.
Old Nov 12, 2023 | 07:54 PM
NSAJMART's Avatar
NSAJMART
Getting back around to this. I started on the cover today and what is bothering me is how pitted it is. I don't know if evopo rust will solve it? Should I get a new one? I can use the acid but I am concerned about the pitting. Thanks for your time.
Old Nov 13, 2023 | 06:18 AM
JWA's Avatar
JWA
Nothing more than my opinion and what I'd do, take all that into consideration.
I; simply use a wire wheel on a drill, remove as much of the loose rust as possible then bolt the assembly back together. Unless the pitted area is actually leaking or porous this shouldn't cause any huge longer-term issues. Like already suggested painting or coating the inside would probably result in that flaking off which you don't want.
Good luck with this!
muhford
Jan 14, 2021 02:29 PM
woodson84
Sep 18, 2019 03:37 PM
XB70
Sep 21, 2011 03:14 PM
murph1
1997 - 2003 F150
Oct 5, 2005 09:20 AM
Caniac10
Jan 8, 2005 05:42 AM
