Supplemental Heater?
Old Oct 31, 2023 | 11:26 AM
WXboy's Avatar
WXboy
I guess a remote starter is in my future.
Old Oct 31, 2023 | 07:15 PM
Strider250's Avatar
Strider250
I ordered the block heater for mine instead of the supplemental heater. So far on a few low 30's mornings with my truck plugged into a timer that starts about four hours before I plan to use it, the coolant is in the 90's and with the fan speed on the fourth setting the truck gets pretty warm by about 5 miles. You might consider adding one to your truck for faster warm up.
Old Nov 1, 2023 | 05:19 AM
senix's Avatar
senix
window sticker will tell you if you have the heater. I do. I also have the heated seats, and that is where it is at.
I start the truck, scrap, put my seat belt on and go. Very shortly the seats are warming my butt, and all is well.
Old Nov 1, 2023 | 06:34 AM
scraprat's Avatar
scraprat
Top Answer: 5
I'm with Senix on the seat warmer, boy it's nice having a warm seat on a chilly ride.
Old Nov 1, 2023 | 08:08 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Originally Posted by scraprat
I'm with Senix on the seat warmwer, boy it's nice having a warm seat on a chilly ride.
Wait til you drive a Ram with the heated wheel too...so nice on those cold winter mornings, even with gloves on. Wife thinks it's too hot but I love it.
To the OP, if it's taking THAT long for it to warm up, you may have a thermostat problem, because these trucks should be throwing out a good amount of heat from the heater core within just a couple minutes of moving down the road (or a few minutes of idling, presuming you get into high idle).
Old Nov 1, 2023 | 08:29 AM
BDWSD22's Avatar
BDWSD22
I checked all the right boxes
Originally Posted by WXboy
All of the light duty diesel trucks and Jeeps I've had before came with built in supplemental heaters of some kind so that the cabin heat would flow quickly in winter. This morning it was 28F here and I drove probably almost a half hour before the truck started to warm up inside. Took absolutely forever to defrost the windshield. Is this normal?
You can add the engine block heater and plug your truck in when you park it. I have the supplemental heater, engine block heater and remote start. The deluxe treatment is the heated steering wheel and seats. It was 27°F this morning and I forgot to plug it in. I got dressed after a remote start and my '22 F-350 6.7L was warm and comfortable 10 minutes later. I'll try to remember to plug it in tomorrow.
Old Nov 1, 2023 | 09:22 AM
scraprat's Avatar
scraprat
Top Answer: 5
Back in 1990 I drove a company Chevy truck off and on during the summer after that I only owned Ford 250/ 350, I've never driven another brand truck. Ford always treated me well and feel they are a better heavy duty work truck than the others. Creature of habit I guess why change what works.
All this extra bling these trucks come with now is just more crap to break down the road. 😉
Old Nov 1, 2023 | 09:28 AM
Pugga's Avatar
Pugga
I live in MA and my diesel does not have the rapid heat option (it was sold initially in NC). I added the block heater which is a heating element in the water jacket, remote start, high idle and seat heaters. The plug the block heater into a timed outlet that gives it power 3 hours before i have to leave, remote start it before I put my boots on and high idle it while I scrape ice or clear the snow.
Old Nov 1, 2023 | 09:49 AM
acadianbob's Avatar
acadianbob
Idling a diesel is mostly a waste of fuel and time here in Minnesota. My diesel friends say that they just do not warm up unless under load.
Old Nov 1, 2023 | 10:01 AM
WXboy's Avatar
WXboy
So this morning it was 21F. Started the truck at 6:07 and drove it to work. By 6:38 the coolant temp had reached 153F. Finally started to get a little warm air coming out of the vents. A few minutes later it was in the 170s and the cab started getting comfy.
Another thing I hate is the lack of fan speed. This truck has the lowest air flow of any truck I think I've ever had. Even on full blast it doesn't really gush out. And any setting below full speed you can't even hear air moving. It's pathetic.
I guess Ford spent their budget on the aluminum body and cheaped out on HVAC.
Old Nov 1, 2023 | 10:05 AM
scraprat's Avatar
scraprat
Top Answer: 5
Pull the cabin air filter problem solved.
Old Nov 1, 2023 | 03:18 PM
99powerstrokedF250
Definitely sounds like you've got a cooling system issue. You should be at full operating temperature long before 30 minutes into your drive if everything is functioning properly. My FIL's '23 is upwards of 150 degrees in the three mile drive to the main drag from his place, and my CTD is about the same, even with the 21 degree morning we had today.
I would suggest that you've got a coolant thermostat that is stuck open. It happens, even on new vehicles. It should NOT take that long to heat up.
Old Nov 2, 2023 | 12:49 PM
  #28
porthole's Avatar
porthole
I've had it on two trucks now, couldn't tell you if it works or not.
Although I don't know if I've ever tried starting out with the heat set to max.
Old Nov 2, 2023 | 01:02 PM
  #29
JoeUser's Avatar
JoeUser
How does one know whether their truck is equipped with it? I don't have the original build sheet, as I bought my '20 XLT used. I do have the heated seats option, along with the Premium package.
Is it just a matter of trying it out, by turning the heat to Max when outside temperature is 30ish degrees? Then, see how quickly heat returns from the vents?
Old Nov 2, 2023 | 03:20 PM
  #30
fireguyed's Avatar
fireguyed
Back a few lives ago, I drove dump trucks. The company would pull the t-stats to not worry about ever overheating... We appreciated that in the winter, too... We would all have various types of cardboard behind the grill to reduce the airflow.
I don't have an oil burner, but I have driven a few and agree that what you are experiencing isn't right; you should be warmer quicker.
