No spark problem
Old Oct 29, 2023 | 12:06 PM
robbyfowler6's Avatar
robbyfowler6
No spark problem
After rebuilding my 351w I went to go crank it up.I cranked but did not start. I made sure timing wasn’t 180 degrees off, so timing should be about right. I check my carb for fuel and it seemed good. So I tested for spark, and saw no spark from my ignition coil. The ignition coil was getting spark 3 months ago before the rebuild, so I would imagine the coil is still fine. So how should I best go about troubleshooting further? Some sort of wiring problem? My knowledge in that area is limited.
Old Oct 29, 2023 | 12:32 PM
Franklin2's Avatar
Franklin2
Get a testlight. Harbor Freight has them cheap. Get the cheap one with the little regular bulb in it. Take the testlight, clip the one lead to a good ground, and probe the NEGATIVE of the coil (one of the small terminals). Get someone to crank it over while you do this. The testlight should blink on and off when it's cranking over. If not, move the probe from the negative to the positive terminal of the coil. With the key on, you should have a constant light.
Do you have the DSII system? If you do, you have a large square silver box on the driver's side inner fender correct?
Old Oct 29, 2023 | 12:38 PM
robbyfowler6
im unsure the specs of it, but yes it is on the drivers side inner fender
Old Oct 29, 2023 | 12:51 PM
Franklin2's Avatar
Franklin2
If you have power at the coil but the negative is not blinking when the engine turns, that silver box is the usual suspect. It's the ignition module.
Old Oct 29, 2023 | 01:20 PM
scottscott's Avatar
scottscott
How to test the ignition system:
Old Nov 1, 2023 | 07:22 PM
robbyfowler6
I replaced the coil and now I’m getting spark. It cranks, barely turns over once and stops, it’s so close might just be the timing.
Old Nov 1, 2023 | 10:21 PM
kr98664's Avatar
kr98664
Please elaborate. Does the starter system reliably get the crankshaft spinning at a healthy speed, even if the engine won't run after you release the key? If the starter speed is slow or erratic, please look at this troubleshooting guide:
https://www.ford-trucks.com/forums/1...w-starter.html
Please note that simple test disables the ignition to make sure improper timing isn't part of the equation.
Old Nov 2, 2023 | 07:27 PM
robbyfowler6
it seems like it is spinning the crankshaft at a healthy speed. It will crank fine, barely bump over once like it’s about to start then go back to cranking and the cycle keeps going.
Marsh90250
22
Oct 9, 2023 02:17 PM
Fessik
Apr 21, 2011 07:02 PM
46fordl
Modular V8 (4.6L, 5.4L)
15
Sep 28, 2007 09:21 PM
frankp
19
Aug 15, 2004 07:17 AM
77sc
Electrical Systems/Wiring
Jan 23, 2002 01:16 AM
