292 Rebuild
Old Oct 26, 2023 | 07:08 PM
Strand10's Avatar
Strand10
292 Rebuild
My 292 in my 1962 F100 Unibody is burning tons of oil. Thinking of swapping with a rebuilt eng. Are there engine rebuild shops that come to the fore?
Old Oct 26, 2023 | 08:15 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Y-blocks have some peculiarities that not every rebuilder is familiar with. I would hang out a bit in the Y-block Forum, and ask questions and for recommendations. There may well be, in your area, a rebuilder that knows, likes, and is skilled at rebuilding them. Good luck.
Old Oct 27, 2023 | 09:32 AM
Greaser007's Avatar
Greaser007
Check out reman engines purchased through AutoZone.
I was looking at their AMC 304 V-8 reman's and my guess is they come with a warranty too if certain installation requirements are met.
I don't know how much oil your 292 is consuming, but I ran a turbo diesel for 15-years which used 1-quart per 350-miles consistently w/ no change.
A quart of oil is much less expensive than fuel.
Old Oct 27, 2023 | 04:45 PM
john jamieson's Avatar
john jamieson
I had a '61 with a 292, when I was a starving student. It started running ruff and missing. The timing chain was super stretched out. Iput a new chain and gears in and a new set of rings and it was good to go. Have tried doing a leak down test to see if the problem is due more to rings or worn valves and valve seals?
Robert111415
Oct 14, 2022 04:24 PM
tigol’biddies
Jun 11, 2021 12:44 AM
praisethelowered17
May 3, 2012 02:07 PM
brownbronco
Mar 2, 2007 05:10 PM
creepin_ford
Jan 26, 2006 09:37 PM
