Sponsored by: Auxito
4.2 v6 engine
Old Oct 26, 2023 | 09:55 AM
David Alcalá's Avatar
David Alcalá
1st Gear
4.2 v6 engine
Hello I currently own a 2001 f-150 with a 4.2L V6. It has 250k miles on it and is giving issues like shaking when accelerating. I’ve come to the conclusion that replacing the motor is what I need to do. I wanted to ask if it would be possible to put a V8 instead of a V6? If it is not possible, what would be the best solution?
Old Oct 26, 2023 | 12:03 PM
BareBonesXL's Avatar
BareBonesXL
A V8 swap would be difficult and expensive, if it's possible. Probably easier to fix the engine that's in it. Is the check engine light on? Are there codes?
Old Oct 26, 2023 | 08:22 PM
85e150's Avatar
85e150
X2 on fix it or another 4.2.
How is the rest of the truck?
Old Oct 27, 2023 | 12:21 AM
Truckwardo's Avatar
Truckwardo
You just need a new truck. Don't put any money in it. I would walk away from it.
Old Oct 27, 2023 | 05:53 AM
Johnny Paycheck's Avatar
Johnny Paycheck
Pull the spark plugs and show us some pictures. With some miles on them, 4.2s like to burn oil and foul spark plugs.
That mileage is a pretty good run for a 4.2. If the truck works fine, I’d just find another 4.2 to throw in.
A v8 would require the transmission and computer, for starters.
Old Oct 30, 2023 | 04:56 PM
jimgnj's Avatar
jimgnj
I have a 2004 Heritage 4.2 with 290,000 miles. The plugs can definitely cause shaking on acceleration and will foul sooner than you think. I would strongly recommend you change the basics, plugs, air filter, gas filter, coil pack and wires.You have very little to lose. I'll bet the 4.2 will run fine.
Old Nov 4, 2023 | 03:47 PM
modeltwoods's Avatar
modeltwoods
4wd Low
How about swapping to a newer, later model EcoBoost V6
If swapping to a V8 is too expensive or too much trouble, would the same thing apply to swapping a newer, later model EcoBoost V6 engine, be possible and easy, or is a bolt on turbo system available for the 4.2? I have a 2003 F-150 supercab stepside pickup with just under 197,000 original miles with the 4.2, automatic trans, 3.55 rear axle. It runs like it was just broken in with low mileage. It doesn't use any oil in between oil changes. The only thing the engine has had replaced since new was the rear main seal and normal routine maintenance items (belts and hoses). It runs like a top, although a slow top, when compared to a 75 Ford F-100 that I swapped a 428 PI engine in, decades ago. I long for the feeling I got when the G forces pushed me against the seat back when floored. No, I'm not a 'youngster'; I'm 75 years young.
Old Nov 4, 2023 | 08:17 PM
85e150's Avatar
85e150
An EcoBoost transplant would be more complicated than a V8. I doubt there is a kit for the 4.2. The 3.8 had a supercharger. You might be able to adapt it. There's a bunch of discussion on other sites if you search "4.2 turbo " or something similar.
Old Nov 22, 2023 | 03:32 PM
tristan0719's Avatar
tristan0719
1st Gear
Would a 4.2 out of a 2000 automatic f150 fit in a 1998 manual f 150
I have manual 1998 Ford F-150 with a locked up motor is it possible to swap it with a 4.2 out of a 2000 Ford F-150?
Old Dec 11, 2023 | 08:12 AM
horsappl's Avatar
horsappl
Trailering
I did just that, but with a 1999 (same as a 2000). If you keep the intake manifold from the 1998, it is an easy swap. I used the intake from the 1999, and the primary difference is the IMRC (1998 was vaccuum operated, 1999 is electric). If you use the newer intake, some rewiring is required. I have mine running fine, but the temp sending unit, AC clutch, and one IMRC sensor are not connected yet. IMRC works fine, but gives an error.
Link below is to show my progress:
https://www.ford-trucks.com/forums/1...o-sensors.html
VanGo3
2021+ F150
Aug 1, 2021 10:06 PM
FXFXR
1983 - 2012 Ranger & B-Series
Jul 6, 2009 10:26 PM
sams6.9
2004 - 2008 F150
Nov 25, 2008 01:07 AM
lincolnman88
1997 - 2003 F150
Jan 14, 2002 10:40 AM
