Sponsored by: Real Truck
Which Lockers?
Old Nov 21, 2003 | 06:27 PM
BigDawg54's Avatar
BigDawg54
Which Lockers?
What would you all recomend for a locker in the rear diff? i dont need hardcore off road lockers, just something better then the POS LS. this past weekend upstate i was all over the place and did not notice a thing with the LS. i only notice it on dry pavement, it locks right up. but i was not impressed on wet muddy fields at all. maybe its just me
-bigdawg
ps- i have the stearling 10.5 rear with 3.73. also, would ford change them to 4.10 if i asked??? not a major issue but one for thought. need more power down low with the 5.4L
Old Nov 21, 2003 | 09:39 PM
99f350sd's Avatar
99f350sd
Been through it 100 times. Just get the detroit and be done with it. search around for the best price...other options are a lock right and a no-slip ..its a better lock right. for the money I would go with the detroit...
Old Nov 22, 2003 | 02:21 AM
xanthias's Avatar
xanthias
I'm sure you could get the dealer to change the gears, just be prepared to pay through the nose.
Of course, if you re-gear the rear, you will have to do the front at the same time.
Old Nov 22, 2003 | 01:36 PM
Biggie's Avatar
Biggie
What size tires are you going with?
If you want 35s or bigger, you might as well get 4.56s or something like that as opposed to regearing from 3.73s to 4.10s.
Does anyone know if there is anyway to get 4.30s with the V-8?
I don't see why they cannot be ordered in that configuration-
with HD trucks, there is no required fuel mileage
lower gears would really help the smaller engine move when hauling loads
I've always heard that going from 3.73 to 4.10 or a similar change is usually not worth the cost of regearing.
nojoke327
Jul 7, 2014 07:08 PM
BigDawg54
Dec 31, 2003 05:49 PM
BigDawg54
Nov 17, 2003 04:58 PM
BigDawg54
Appearance & Dress-Up
Oct 25, 2003 06:53 PM
TUNA1
May 20, 2002 11:23 AM
