Leaking Fuel Rail?
Old Oct 23, 2023 | 09:37 PM
jackpilarski96's Avatar
jackpilarski96
Trailering
Leaking Fuel Rail?
Just swapped a 351w into my 94 f150. When I crank, fuel sprays out (towards firewall) from behind the intake plenum. It’s coming out on the passenger side (cylinder 4 area). I confirmed that the fuel lines are not leaking from where they hook up to the fuel rail. Could this be a broken fuel rail? Or leaking injector? All help appreciated.
Old Oct 23, 2023 | 09:58 PM
Conanski's Avatar
Conanski
Could be an injector O-ring or the crossover hose between banks.
Old Oct 24, 2023 | 12:52 AM
TexasGuy001's Avatar
TexasGuy001
Did you use the 351 fuel rail or stretch the 302 fuel rail to fit? Not sure that is even possible but just a thought.
Old Oct 24, 2023 | 09:00 AM
jackpilarski96
Trailering
351 fuel rail. All new injectors.
Old Oct 24, 2023 | 12:50 PM
C6Scott's Avatar
C6Scott
mine did this and the leak was in the rear cross over line between the right and left fuel rail. Best way to tell is to put on some safety glasses and have an assistant turn the key to on while you look at the location and see where it’s squirting out. bottom line is the only way to know for sure is to try and see it leaking.
MAD MAXINE
Apr 1, 2021 03:20 PM
dyoungen
Nov 11, 2012 09:18 PM
clbostian
Oct 10, 2010 11:09 AM
86bluebronco
1978 - 1996 Big Bronco
17
Jun 24, 2010 09:39 AM
97F250LD4X
Jun 14, 2010 11:49 PM
