Fuel filter compatibility
Old Oct 21, 2023 | 04:28 PM
mhollem's Avatar
mhollem
Is the 6.7L diesel fuel from 2020 compatible with my 2022?
K&N has a fuel filter that says compatible with 2020
Old Oct 21, 2023 | 04:35 PM
FishOnOne's Avatar
FishOnOne
I would only use Motorcraft fuel filters for the fuel system.
Old Oct 21, 2023 | 05:40 PM
4wd6.7L's Avatar
4wd6.7L
Compatible 17-23 yes, but I tend to agree with the above statement, I would stick to Motorcraft for the fuel filters.
Old Oct 21, 2023 | 05:59 PM
mhollem's Avatar
mhollem
Thanks. I'll look at the Motorcraft.
Old Oct 22, 2023 | 07:13 AM
senix's Avatar
senix
another endles vote for OEM fuel and oil fiters.
Old Oct 23, 2023 | 03:44 PM
rufushusky's Avatar
rufushusky
One more vote for the OEM filters, very limited aftermarket options for the 2017+, Fleetguard and Donaldson don't offer anything, Baldwin does, rebadge brands like K&N and AFE offer some and then you into the no name brands that who knows if they actually meet OEM spec. IMHO of course, unless you swap out the filters for a threaded filter head, I would stick with OEM.
Old Oct 23, 2023 | 04:31 PM
acdii's Avatar
acdii
With how sensitive the CP4 is to contaminants, STICK with what works best, true Motorcraft! Be careful though there are copycat kits out there, especially on Amazon. If the part number is stamped on the plastic filter housing, its a fake, True motorcraft numbers are etched in.
Old Oct 23, 2023 | 04:44 PM
Joe T's Avatar
Joe T
The cheap ones get stuck in the lower tank housing.
Old Oct 23, 2023 | 04:50 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
While I agree on sticking with only motorcraft filters, the trash that kills the CP4 comes from directly within the CP4, not after passing through the filters.
Qwazert
6.2L V8
Oct 26, 2024 09:17 PM
wahlturfcare
Apr 26, 2017 12:48 PM
61 uni
Nov 22, 2008 08:20 AM
