Modular V10 (6.8l)
V10 head issues
Old Oct 21, 2023 | 03:14 AM
Tim 99v10's Avatar
Tim 99v10
Trailering
V10 head issues
So I bought a 99 v10 Last night and I noticed some rust underneath but I didn't look at the moter all to well when I was buying it. It has a pretty good exhaust leak and I got to looking and all but 2 of the manifold bolts are rusted clean off on each side( was a plow truck). So I'm wondering what the best way to go would be? I do have another 99 that has good heads that has bad rings would it be easiest just to swap the heads out of the better set? Can I pull the heads without jacking up the cab? I do have a welder so I can attempt to remove the rusted bolts but they are pretty far gone and if I have to pull the head anyway Is it worth messing around trying to remove those bolts? It has 185k on it if that makes a difference. I like working on them and have 2 helpers to set the head back on gently. Any help/advice is greatly appreciated!
Old Oct 22, 2023 | 12:00 PM
super 6.8's Avatar
super 6.8
I would swap heads and put new studs in before doing the swap.
Old Oct 22, 2023 | 06:17 PM
Tim 99v10's Avatar
Tim 99v10
Trailering
So I guess how would be the best way to get the heads pulled? I don't have access to a lift so the cab will have to stay on. Does the moter need pulled out or can I do it when the moter is in there?
Old Oct 22, 2023 | 07:10 PM
super 6.8's Avatar
super 6.8
Never done it personally. I don't believe you have to lift the engine. There is just a lot of stuff to remove to make room for it,
Old Oct 22, 2023 | 09:35 PM
Charlie98's Avatar
Charlie98
Actually, you have to drop the engine to even get the valve covers off, if I'm not mistaken. I understand that the trick is to pull the pin on one of the motor mounts and lower the engine in the engine bay to give you enough clearance to get a valve cover off... I don't know if that translates to pulling a head, which is something that probably needs a little more room.
lance65
Jul 3, 2018 08:09 AM
Mazz
Oct 7, 2015 01:53 AM
Packrat Super duty
General Automotive Discussion
Mar 10, 2015 04:52 AM
mizzitch
Modular V10 (6.8l)
Nov 18, 2006 08:19 AM
jcrice
Modular V10 (6.8l)
Nov 14, 2003 02:05 PM
