Random mods talk
Old Oct 22, 2023 | 01:18 PM
Overkill2's Avatar
Overkill2
Originally Posted by FishOnOne
Was sad to hear Bill passed away
Yeah it was... love him or hate him, he knew his stuff. Saw another YouTuber, not ARod, post up a thanks and RIP video for him...
Old Oct 22, 2023 | 07:23 PM
speakerfritz's Avatar
speakerfritz
Originally Posted by Overkill2
By saying "locking out 6th gear," I mean using the plus (+) and minus (-) buttons to lock out 6th gear, or any other gear, by pressing the minus button and taking 6th off the display which makes 5th gear or any other lower gear the top gear...
makes sense
Old Oct 23, 2023 | 07:29 AM
Overkill2's Avatar
Overkill2
I also used to drive around in Tow/Haul Mode which helped IMO. I may have to start again now after seeing the video from Bill... just thought of this (T/H Mode) now actually... when the trans is not in T/H mode, it lingers in the higher gears at lower speeds, which lugs the engine.
Old Oct 23, 2023 | 07:43 AM
JoeUser's Avatar
JoeUser
I read your second sentence too fast, and missed the "not in T/H", and thought "??".
I'm going to try using T/H mode for commuting over the next tank of fuel, just to see the effects. Thanks for the tip.
Old Oct 23, 2023 | 07:55 AM
Overkill2's Avatar
Overkill2
When the T/H mode is NOT engaged, the 6R140 stays in the higher gears in lower speeds that causes the engine to lug when you hit the throttle again... If you're slowing or braking...
Old Oct 23, 2023 | 09:28 AM
JoeUser's Avatar
JoeUser
Another factor, in my case, is that I've got the 10-speed auto. Guess I'll have to research T/H mode and how that affects the gearing with that particular trans. I'm sure that what you experience with your 6-speed is different than what someone with a 10-speed experiences...
Old Oct 23, 2023 | 09:56 AM
scraprat's Avatar
scraprat
Top Answer: 5
Seeing 8-10 are overdrive gears it could be as simple as locking 9 & 10 out or 8th even and trying 7th incertain circumstances. A little testing would be needed.
Old Oct 24, 2023 | 07:57 AM
Overkill2's Avatar
Overkill2
I actually forgot about T/H mode... been driving it in now. I like it... it makes the truck almost feel like a stick shift truck. Some guys won't like that but it reminds me of my 94 4Runner in my garage with the 5 speed. Slows you down better on hills. Also reduces engine lugging as it downshifts more...
Old Oct 24, 2023 | 07:58 AM
Overkill2's Avatar
Overkill2
I lock out 6th at 50mph or less...
rblomquist
Car/truck Buying Advice
May 24, 2026 09:53 AM
Furr308
Colorado Chapter
Aug 1, 2018 09:02 AM
JBronco
1978 - 1996 Big Bronco
Mar 21, 2013 02:32 PM
Mikproc
Connecticut Chapter
Mar 23, 2010 05:51 PM
