Rear differential fluid question
Old Oct 19, 2023 | 11:38 AM
Jamon Norton's Avatar
Jamon Norton
I just had the rear differential rebuilt on my truck. It has the factory limited slip. I was wondering if it required limited slip additive. I know the fluid is 75W 140 I believe.
Old Oct 19, 2023 | 12:11 PM
97-psd's Avatar
97-psd
It will depend on the fluid that was used. Some have the additive some will need the additive added. Do you know what fluid was used?
Old Oct 19, 2023 | 12:15 PM
Tpayne621's Avatar
Tpayne621
It will need the additive or it will chatter more the likely. Like previous post mentioned some fluid now days have additive in it already.
Old Oct 19, 2023 | 12:31 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Like Ben (97-psd) said, drive it a bit and see if it needs the Motorcraft XL-3 Friction Modifier. I have Amsoil 75w140 in the rear LSD of my truck and even though it is supposed to have friction modifier in it, I needed to add about 1/3 of the XL-3 bottle. Some fluid manufacturers specifically state no friction modifiers needed or friction modifiers included (or at least they used to), but each application can be a bit different.
Old Oct 19, 2023 | 12:57 PM
ArmyLifer's Avatar
ArmyLifer
I used the Mobil 1 version of the fluid and no additional friction modifier needed.
Old Oct 19, 2023 | 01:06 PM
Jamon Norton
Thanks for the answers
Old Oct 20, 2023 | 06:37 AM
FordTruckNoob's Avatar
FordTruckNoob
Or switch to a worm differential (like a TrueTrac) and never have to worry about additives or worn friction plates again.
Old Oct 20, 2023 | 06:45 AM
MARCSPSD's Avatar
MARCSPSD
2001 Excursion 4x4 7.3 PSD 1 owner me
Called Mobil 1 tech hotline several year ago with the same question as yours.
Said the ATF has the modifier in the diff oil. Only add the modifier if the truck chatters at slow speeds while turning. My rear end needed 1 small bottle of the Ford modifier.
Original differential still in service with NO issues. 397k all driven by me!
Have changed the rear differential fluid several times over the years.
Tpayne621's Avatar
Tpayne621
Or even better yet get a factory elocker out of a 12+ truck and have the best of both worlds at the flip of a switch for cheaper. Sometime very cheap.
Old Oct 20, 2023 | 06:49 AM
FordTruckNoob
I wish there 's such a thing as an e-locking worm differential. Automatic locking for most circumstances and then you can force the lock in the absolute slipperyiest (is that a word?) conditions.
Old Oct 20, 2023 | 08:50 AM
John in OkieLand's Avatar
John in OkieLand
That is what was installed in my '02 Excursion's rear diff, a TrueTrac and 3 bottles of Amsoil's rear diff lube.
I don't recall any mention, or charge for Friction modifiers when it was installed.
Old Oct 20, 2023 | 11:24 AM
RA101725's Avatar
RA101725
Banned
That would be cool especially for rwd trucks that need a tiny little extra low speed traction in dicey situations. Like a big truck with a true side-to-side diff locks, you only leave that on for as long as needed.
Old Oct 20, 2023 | 12:33 PM
Tpayne621's Avatar
Tpayne621
I put one in mine. Got it off marketplace for $100. Just wired it to upfitter switch. Works well. Pretty simple swap.
Old Oct 21, 2023 | 12:17 AM
S.A.E.'s Avatar
S.A.E.
4wd Low
Do you have the owner's manual?
Old Oct 22, 2023 | 11:43 PM
carl2591's Avatar
carl2591
Do I known for sure that will work? Drive line will match up to u joints etc. How much they run and how to get the electrical to work.
