Window trim removal
Old Oct 18, 2023 | 06:47 PM
john jamieson's Avatar
john jamieson
Window trim removal
Any tips or advice on removing the trim during a windshield seal replacement?
Thanks. John
Old Oct 19, 2023 | 05:54 AM
AZSCAWPION's Avatar
AZSCAWPION
It's pretty straightforward. Remove trim after you pull the windshield. Also, be sure to set the trim to the seal before you reinstall the windshield. Don't try to remove or install the trim with the windshield installed.
Old Oct 19, 2023 | 08:12 AM
resonateur's Avatar
resonateur
....as Tony said. To remove the old seal and windshield, cut the seal on the inside and push the glass forward and out gently onto a pad or the helping hands of an assistant. Installation is the same as most older vehicles so any online demo should work.
Old Oct 19, 2023 | 06:17 PM
john jamieson
Thanks for the info. The hardest part will be removing all the silicone I used to try and stop the leaks.
Old Oct 22, 2023 | 01:22 PM
Thunderkiss1965's Avatar
Thunderkiss1965
yes, yes it will. I have found gasoline and a brass wire brush to be the most effective way to remove silicone. Or plastidip if you ever come across it.
maverickfe390
Paint & Bodywork
Jun 5, 2010 10:25 PM
crestfallinman
May 18, 2008 08:42 PM
AzPete
May 3, 2006 01:35 PM
Dave_Exp
Mar 10, 2002 09:38 PM
