Sponsored by: Real Truck
F250SD D50 question
Old Oct 18, 2023 | 09:11 AM
Mudsport96's Avatar
Mudsport96
F250SD D50 question
Hey guys, I hang out over in the Older truck section so not in here very often.
Anyway, I have a question that I'm sure someone here can answer.
The D50/60 with the unit hub bearing assembly, do they still have the stub shaft support needle bearing in the back of the spindle like the old serviceable bearings?
Guy at work is trying to convert TO the unit hub assembly and claims he doesn't need the stub bearing to support the axle. I disagree, but like I said I'm used to the older trucks that use them.
Old Oct 18, 2023 | 01:17 PM
WWR's Avatar
WWR
Yep, just call up photos on RA for the model year bearing you think you'll be using (maybe say 2001?)
Some of the offerings will have multiple views you can flip through, ie front, side, rear etc. I think you'll find a needle bearing there.
Old Oct 18, 2023 | 02:09 PM
Mudsport96's Avatar
Mudsport96
I see that they seem to come with the equivalent installed in the back of the housing.
BUT.. he ordered a "bare" one from ebay because it was cheaper. No studs etc.. so he is in for a rude awakening I believe.
RigCity
Aug 8, 2017 10:35 AM
bronco6767
Apr 15, 2016 11:44 AM
got2bjoester
Escape & Escape Hybrid
26
Dec 24, 2015 03:13 PM
Shattered
Nov 23, 2015 12:59 AM
littledre1
Jun 6, 2007 10:57 PM
