Sponsored by: Auxito
tensioner
Old Oct 14, 2023 | 07:50 PM
Penniesworth's Avatar
Penniesworth
Trailering
tensioner
2001 4.6W Replacing all the timing chain componants. The kit had two spacers for the tensioners. There wasn't a spacer on either of the original tensioners. Called the manufacturer of the parts and didn't want to stay on the phone for 2 hours waiting. The old parts look identical to the new ones. I'm thinking maybe the spacers are to limit the amount of oil going into the tensioner if there is a high pressure/volume oil pump installed, any answers? Cheers
Old Oct 16, 2023 | 12:36 PM
manicmechanic007's Avatar
manicmechanic007
I believe that plate is both a gasket and an oil restrictor.
I would use it with either pump
Old Oct 16, 2023 | 01:19 PM
Penniesworth
Trailering
the chains were actually rubbing on the shaft on the tensioner. I noticed right off that someone change the tensioners recently. Bolts mixed up etc. the tension shafts (plungers) had come through the guides. most likely to much oil pressure getting to the tensioner. Thanks for info.
J. Bruce
1997 - 2003 F150
Nov 21, 2023 06:50 PM
Frawillor
2004 - 2008 F150
Oct 29, 2021 09:39 AM
slovride
Modular V8 (4.6L, 5.4L)
Feb 27, 2013 09:17 PM
sstam6
4 Cylinder Engines
Jul 20, 2003 08:48 PM
moonman 64
1997 - 2003 F150
Feb 7, 2003 06:22 PM
