So one thing I've noticed about this F-250 is that the rear wheel drive traction sucks. Out of the 20 pickups I've had over the last 28 years this one by far is the worst when it comes to getting a grip. I don't know if it's the stock Goodforayear Wrangler tires, or the fact that it's nose heavy because it's a diesel truck, or if it's the really stiff suspension that doesn't allow as much flex as a 1/2 ton truck. But this thing will spin the tires at the drop of a hat. Slight incline in dry grass....spin. Pulling out of a gravel driveway onto a paved road...spin. Driving straight up my gravel road on an incline....spin. It's annoying. I can only imagine how miserable it's going to be when winter gets here.
So, I'm looking at options for adding a LSD to the Sterling 10.5. I don't really want an e-locker. I want something that's automatic, seamless, and smooth. Looks like a lot of guys have gone with the Detroit TrueTrac. What other options are there? TrueTrac is $900 bucks. Is there anything that works great that's less expensive?
About 100-200 lbs in the bed. Seriously.
Gotta remember these are now aluminum body trucks, so the rear end is even lighter than it used to be. But if you throw some weight in the bed it helps out a lot.
That or ease into the pedal a bit more - my FIL's new '23 with the 6.7 doesn't spin the tires that easily in grass or gravel, unless he really gets into it.
My short bed SD scales at almost 3200lb on the rear axle with a full tank of fuel...is that considered light? Not much lighter than an entire Toyota pickup haha. With 900+ lbft of torque going to 1 tire, traction can be challenging. If fenese of the go pedal doesn't work then better tires and/or an LSD might be the way to go. If you haven't already done so, you could try lowering the tire PSI when not loaded.
I take it very easy. I drive like a 90 year old man. It doesn't seem to be the issue. I find myself flipping the **** to 4x4 to perform tasks I've never had issues with in the past.
Originally Posted by skunkoffroad
Is this your first modern diesel?
As said above the light weight body dosent help the situation. Add weight to the bed preferably by the tailgate.
No this is my 5th diesel, but it is my first HD pickup.
Light on the rear axle, heavy on the front axle, lots of low end torque, hard stiff suspension and tires combined with an open diff = not very much traction. At least you have the magic **** and yes, a locker or LSD would help you avoid running in 4wd as much. All my trucks have a LSD rear.
Yes, pickups have most of their weight over the front end so you need to employ other methods like four-wheel drive, locking differentials or adding weight in the bed. It's just simple common sense and physics. I air down my tires to 55psi when not towing or hauling a heavy load and that helps with ride and traction.
My truck (see signature) tips the scale at 7900 with 1/4 tank of fuel and a 170 pound driver. 4680 pounds, or about 60% of the truck weight, is on the front axle. Combining the nose heavy truck with a high torque turbo-diesel engine can make getting the truck moving without spinning your rear tires somewhat challenging in certain conditions.
Yes, just common sense. Weight in the bed to start. I had a Ford Ranger that was worse than a car without weight. That's why I like 4x4, needs to be used anyway.
And Goodyear Wranglers suck for traction. Good wear, great for towing. Lousy for traction.
I'll respectively disagree with your assessment. I use mIne both on and off road with no issues. In snow also. Now if you need big heavy duty side lugs for extreme mud conditions then Wranglers probably won't make you happy.
