6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Turbos swap
Old Nov 26, 2023 | 09:58 AM
CrazyCajun's Avatar
CrazyCajun
Turbos swap
I just purchased a new set of turbos for my 6.4. I read about installing a new oil feed line and that there’s an upgraded oil feed line if so where do you get it? I also read there’s upgraded drain tubes as well can’t find them. There is a drain tube for each turbo right. I search and find the high pressure drain tube new but nothing when searching for the low pressure drain tube, are they the same? Appreciate any help thanks in advance
Old Nov 26, 2023 | 10:10 PM
Evan_P's Avatar
Evan_P
The upgraded lines are for the 6.0 powerstroke. You can choose to replace the feed line and the drains if you would like, but it isn’t always needed. What should be replaced is the sealing washers on the feed line, the drain seals for both turbos and the up pipe gaskets.
Old Nov 27, 2023 | 01:56 PM
CrazyCajun's Avatar
CrazyCajun
Thank you so much for your response. I’m going to purchase new drain tubes just so when I pull the old tirbos out I can have everything ready and new. I also just ordered another feed line I was afraid of the old one having a buildup inside and not having a full flow to the new turbos. I got a gasket and seal set with the turbos but not the drain tube seals thanks again for your help.
White_stang
Mar 17, 2022 08:45 AM
MONAVIERONJON
Jan 26, 2021 02:46 PM
tiredlr
Jan 7, 2013 08:23 PM
amill
Nov 7, 2012 04:54 AM
onuredneck707
Jul 20, 2011 11:16 AM
