Engine reverts to idle while driving.
I had the pickup running great with the new injectors but suddenly it started reducing power to idle while drving on the highway, then when I press the accelerator several times it regains the power.
I checked for codes but no codes available. I replace the ICP and IPR but remains the same. Before I replace the two sensors the RPM was fluctuating between 700 to 1100. now steady at 650.
New oil filter, new oil, Rev-X.
I read of different, owners that have the same problem and still can't find a solution.
If anyone know about this problem. I would like to hear from you
RGDS K Leerdam
https://www.ford-trucks.com/forums/1...low-sound.html
Also, if all you have is ScanGauge, then you are probably not retrieving ALL of the codes stored in the PCM. ForScan is what you need.
