1997 4.2 low idle miss rough idle at 1050 rpm runs rich at idle and codes for all 4 o - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Reload this Page >
Old 04-15-2016, 08:54 AM
Chris Chap
Chris Chap is offline
Chris Chap is starting off with a positive reputation.
97 4.2 low idle miss worse in gear says 35 to 42 percent load in park at idle on engine and drops some above 1100 rpm using scan tool and has 6 02 sensor codes 2 codes for rich with 2 codes heater malfunction belive on both upstream sensors and heater malfunction on both downstream sensors had bad carbine on plugs replaced all them slight help there no noticeable problem under load on the Road but same thing coasting at lower idle or just above 02s all but one reading 750 to 935 mv.except one it is 0 to 400 mv could one cause codes on all sensors or egr problem have cleared codes several times same ones come back after 15 minute run no other codes could possibly be electrical definitely runs rich at idle any suggestions ?
sawduck
Ranger & B-Series
05-11-2017 06:43 PM
Panama1
1997 - 2003 F150
01-05-2017 10:46 PM
Suprawill1
Escape & Escape Hybrid
12-27-2016 01:36 AM
fordpride
15
05-23-2016 01:00 PM
TheDoveNestVansion
3.8 & 4.2L V6
05-15-2016 03:57 PM
Quick Reply: 1997 4.2 low idle miss rough idle at 1050 rpm runs rich at idle and codes for all 4 o
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
