1978 - 1996 Big Bronco
E4OD Won't shift from Park, except w/key in Access. Position will shift
Old Oct 9, 2023 | 12:41 PM
Tim Hodgson's Avatar
Tim Hodgson
@Mark Kovalsky et al.,
This started about 4 months ago. My 1995 Ford Bronco E.B. with the 5.8L engine and the E4OD transmission will not shift from Park to gears. But w/key in the Accessory Position it will shift into the gears plus neutral.
So to start it the vehicle. I have to do this:
1. Start the engine.
2. Stop the engine by moving key into the Accessory Position.
3. Move the shifter into Neutral.
4. Start the engine, shift from Neutral into gear.
5. With engine running, shift into Drive and go.
6. Note: If at any time I shift into Park, for instance in a parking lot, I cannot get it to shift into any gear or neutral and I need to restart the above process.
I read Mr. Kovalsky's post with photo about the two torx bolts coming out of the back under the steering column. I have checked and that is NOT my problem.
Any suggestions?
Any things I should check or photo and post up to help you help me better?
Old Oct 9, 2023 | 08:23 PM
projectSHO89's Avatar
projectSHO89
See your other post for this issue for a response.
Old Oct 10, 2023 | 12:48 PM
Tim Hodgson
See this thread:
https://www.ford-trucks.com/forums/1...accessory.html
NomadFord
2009 - 2014 F150
Jul 21, 2020 08:58 PM
93flareside 7.3 swap
Nov 4, 2018 10:17 PM
nomadw8
Nov 3, 2018 10:14 PM
Duncansm
Jun 6, 2014 06:00 PM
little_scrapper
13
Aug 8, 2011 02:02 PM
