1978 - 1996 Big Bronco
AOD or E4OD??
Old Feb 11, 2004 | 01:21 PM
Hubone90XLT's Avatar
Hubone90XLT
AOD or E4OD??
How do I know which transmission I have? Ive looked in the Chiltons repair manual and it doesn't say. I have a 90 Bronco XLT with a 5.8...
Old Feb 11, 2004 | 01:34 PM
Kemicalburns's Avatar
Kemicalburns
if its a 4speed auto then you have E4OD. if its a 3speed then you have a C-6. the AOD was never offered with the 351 in our broncos or trucks
Old Feb 11, 2004 | 02:27 PM
90ebbronc's Avatar
90ebbronc
Also if the gear selector says P R N OD D 1 its the AOD. If it says P R N D 2 1 and has push button OD then its the E40D. If it has P R N D 2 1 then its the C-6.
Thats how i understood my ownders manual anyway, but it may be different for the 5.8.
Old Feb 11, 2004 | 02:40 PM
jimandmandy's Avatar
jimandmandy
Another way to tell is to look a the oil pan. An E4OD pan has 20 bolts. Mine also has the word "Metric" stamped into the pan.
Jim
Old Oct 18, 2023 | 03:03 PM
SeminoleChad's Avatar
SeminoleChad
4th Gear
Just learned this myself, look on the label inside the driver's side door, if it says "E" under transmission it is an E4OD, "G" it is a C6.
