Death Wobble question
Old Oct 11, 2023 | 08:15 PM
JoeUser's Avatar
JoeUser
So, basically go through your entire suspension, checking everything. Got it. Good to have a list to follow, thanks for the link.
Last edited by JoeUser; Oct 11, 2023 at 08:16 PM. Reason: Overlooked the section on the stabilizer, doh
Old Oct 12, 2023 | 10:02 AM
tbristle's Avatar
tbristle
Thank you for taking the time to post!
Old Oct 18, 2023 | 12:17 PM
acdii's Avatar
acdii
Originally Posted by Overkill2
Okay I'm not knowledgeable in death wobble problems and solutions but I remembered a post here that referenced a company that seemed to have a lot of info on this... just found it, finally.
Here's the post here.
Here's the link to the death wobble page on their website here. Alignment specs...
Just FYI.
Pretty much sums it up. A loose part will kick it off for sure. A good damper will stop it before it starts, but is the the fix for it, just a band aid. If parts are all good, and it still happens, which is quite possible, then the Caster is too close to zero. An alignment shop, if they are good and specialize in heavy trucks would be able to figure it out too.
Heres the thing, while everything checks out with just a tiny bit of play in it, the combination of the whole can add up to DW.
lasallen
Apr 4, 2018 09:07 PM
RubyRedWV
Mar 20, 2017 01:57 PM
bkuuz1
6.7L Power Stroke Diesel
Jan 11, 2017 09:30 AM
jdenny21
Apr 15, 2014 10:18 PM
mcrespousa
Oct 21, 2009 05:12 PM
