Speedometer cables
Old Oct 8, 2023 | 10:56 PM
Marsh90250's Avatar
Marsh90250
Speedometer cables
1990 F-250 4x4 XLT Lariat 5spd manual with Cruise control
looking for a new speedometer cable. I replaced the Speedo gears, truck finally reads the right speeds. Months later Speedo cable finally “broke” internally (I’m guessing).
My speedo needle dances up and down while I go down the road. I looked at some Speedo cables online and some cables are longer than others (I have a two door which length do I need?) And some say with or without cruise control. I have cruise control.
I couldn’t find the part on Jeff’s Bronco Graveyard. Rockauto parts list has limited info on some of their parts, I might just get the 72” length w/ cruise control, but I would appreciate some assurance if any of you would be kind enough to provide it!
thank you very much
Old Oct 9, 2023 | 08:22 AM
jas88's Avatar
jas88
Since your speedo doesn't work anyway, why not pull your cable out and measure it?
Old Oct 9, 2023 | 08:54 AM
Marsh90250's Avatar
Marsh90250
because I don’t want to pull my cluster twice. It’s my daily. You’re probably right though.
Old Oct 9, 2023 | 11:01 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Disconnect and remove the cable. Reconnect the electrical and put a screw or two back on to hold it in place. Leave the bezel off for the time being.
F-250 WARHORSE
Jan 9, 2017 05:16 PM
Yaga1973
Apr 19, 2012 09:30 PM
dcarnut1
Jan 5, 2008 04:21 PM
49willard
Feb 15, 2007 11:43 AM
evin
Apr 28, 2004 05:52 PM
