Speedo, cruise
Old Jan 5, 2008 | 03:13 PM
dcarnut1's Avatar
dcarnut1
Speedo, cruise
I have just bought a 94 F250 4x4, 460, 5 speed, and I am trying to work out a few bugs. First of all the speedometer jumps about 5mph over 65. Is this caused by a bad cable or gear? Next the cruise control will jump between accel and coast. In my previous vehicles, the cruise worked off of the speedometer. Is the speedometer causing the cruise to not work properly?
Old Jan 5, 2008 | 04:14 PM
dixokai's Avatar
dixokai
It doesn't have a seedo cable... You probably have a bad or dirty VSS. I have not personally changed mine but I understand they don't cost much. Like $20.00 or so.
Old Jan 5, 2008 | 04:21 PM
lostin90s's Avatar
lostin90s
The sensor for speedo (its electric) Is on top or rear diff. You can clean it check wires and see. If not fix maybe sensor. Good luck
