1992 E350 Brake part Identification
Old Oct 7, 2023 | 11:14 AM
MrPJ1751's Avatar
MrPJ1751
6th Gear
Question 1992 E350 Brake part Identification
Along the driver side rail is the ABS master control unit. from there a brake line goes to a small part with an electrical connection and has a round metal base that attaches to a brake line "brass t" then the line goes to the front wheels. I can't seem to find what this called.
Apparently I can't load a picture. I have tried 2x but it never attaches to this post.
I changed from Brave browser to Chrome and the image is below.
Old Oct 7, 2023 | 11:18 AM
MrPJ1751's Avatar
MrPJ1751
6th Gear
Old Oct 7, 2023 | 11:20 AM
MrPJ1751's Avatar
MrPJ1751
6th Gear
Thanks to anyone and everyone that replies.. Hope to meet see you at this years Daytona Turkey Run.. That is if we can figure this out.
Old Oct 7, 2023 | 11:26 AM
E-350 SuperDuty 4x4's Avatar
E-350 SuperDuty 4x4
It appears to be a brake light switch.
Old Oct 7, 2023 | 11:46 AM
MrPJ1751's Avatar
MrPJ1751
6th Gear
​​​​the brake light switch is on the pedal.... is this a secondary that can be eliminated?
Old Oct 7, 2023 | 12:06 PM
E-350 SuperDuty 4x4
Its likely being used as a cruise control disengagement switch so when you step on the brake the cruise control disengages.
Old Oct 7, 2023 | 12:12 PM
MrPJ1751's Avatar
MrPJ1751
6th Gear
Thanks because this vehicle had cruise but it does not work currently. I did find a part number on that blue tag #9f924 which brings up similar parts... I am researching it now.. but Thank you so much!
Old Oct 7, 2023 | 12:17 PM
MrPJ1751's Avatar
MrPJ1751
6th Gear
Talking SOLVED !!! Thanks
1993-1997 Ford F-350 - Cruise Control Switch - Direct Fit, Sold individually
https://www.carparts.com/details/Ford/F-350/Replacement/1993-1997/RF50540002.html?TID=gglpla&origin=pla&&&gclid=CjwK CAjwg4SpBhAKEiwAdyLwvBSTitjrOS0VDeebTNzcD3jTmwINrF gqcn5zoK3eqc_iFrIAqEfFBBoCO0oQAvD_BwE&gclsrc=aw.ds
Old Oct 7, 2023 | 02:40 PM
tabijan's Avatar
tabijan
Not adding anything to the question at hand, just thinking out loud.
So if there’s no brake fluid pressure, stepping on the brake pedal won’t disengage cruise control? There has to be more to the circuitry. Like if you apply the brakes and the sensor doesn’t pick up increased brake fluid pressure it’ll disable cruise control until the fault is reset.
Sixto
07 E350 5.4 196K miles
Old Oct 7, 2023 | 05:53 PM
etinpa's Avatar
etinpa
I don't have any service manuals from the 1990s but, from the 2002 service manual:
"Normally, when the brake pedal is depressed, the speed control module deactivates the speed control system. Under increased brake pedal effort, the deactivator switch, a normally closed switch, will open and remove power to the speed control servo clutch, releasing the throttle independent of the speed control module."
From the Vehicle Speed Control Wiring Diagram Overview page:
Old Oct 7, 2023 | 10:55 PM
tabijan's Avatar
tabijan
Interesting, thanks! So it’s a backup to the brake pedal switch.
Sixto
Old Oct 8, 2023 | 04:56 AM
manicmechanic007's Avatar
manicmechanic007
It is the BOO (brake on / off) switch that the processor uses for many functions including cruise dump
You will have trouble with it disconnected.
The trans will shift funky and the cruise will likely not set
Old Oct 8, 2023 | 08:29 AM
etinpa's Avatar
etinpa
Just to be clear, the BOO (Brake On Off) switch is the same as the BPP (Brake Pedal Position) switch, not the hydraulic pressure switch that started this thread.
Old Oct 8, 2023 | 08:40 AM
manicmechanic007
The pedal position switch is a different switch entirely
The BOO switch is the pressure activated switch
Old Oct 8, 2023 | 08:54 AM
etinpa's Avatar
etinpa
The BOO switch is (as shown on the attached Ford wiring diagram) "Closed with brake pedal depressed".
The "Deactivator Switch" shown in the Speed Control Diagram (see post #10 in this thread) opens with 125+ psi in the brake line.
adamsquared
Nov 13, 2023 08:01 AM
kurthb
Jul 14, 2022 05:57 PM
brc777
1997 - 2003 F150
13
Nov 16, 2020 09:04 AM
BroncoII85
Bronco II
Jan 23, 2006 09:52 PM
