View Poll Results: Which to replace 1st...
Oil pan
12.50%
diff Cover
25.00%
trans pan
62.50%
Voters: 8. You may not vote on this poll
What to get.....?
Old Oct 14, 2023 | 10:44 AM
  #31
FishOnOne's Avatar
FishOnOne
Originally Posted by scraprat
On the 21 never...I'm not crawling under there to check it.
On the 16 everytime I hookup the 5th wheel. Dipstick is right next to the oil dipstick.
So when was the last time you had to add fluid after checking it on your '16?
Old Oct 14, 2023 | 10:51 AM
  #32
scraprat's Avatar
scraprat
Top Answer: 5
Originally Posted by FishOnOne
So when was the last time you had to add fluid after checking it?
Never...but can be said about my oil in either truck, never needed to add any.
Doesn't mean I won't check them when they're in your face. But then I check power steering fluid, coolant and battery acid... crazy routine. 🤪
As far as other axle fluids if there is no puddles under the truck and no oil residue on axles all is good.
Old Oct 14, 2023 | 11:35 AM
  #33
FishOnOne's Avatar
FishOnOne
The only reason I check the engine oil is verify there's no diesel leaking into the crank case. The transmission fluid should be checked while the engine is running making it useless to check engine oil at the same time.
Old Oct 14, 2023 | 01:34 PM
  #34
chadstickpoindexter's Avatar
chadstickpoindexter
Originally Posted by rufushusky
I don't think they do... of course they famously don't have dipstick tubes either. I can't totally hold that against them however since my 6R140 didn't have a drain plug from the factory either, like I said I had to go the dorman route.
Given your assumed limited exposure to road salt, the pan is a very easy swap. If you want to save a few bucks, I would go the dorman route for the drain plug. The 10R140 is a thermally regulated environment, not sure the aftermarket pan will really be of much benefit. If you can handle a DPK, a pan swap is a breeze. I agree on the service intervals, I get leery anytime an OEM says the service interval is longer than the warranty period. I plan on servicing my 6R140 on 50-60k intervals. That has served me well on every other automatic transmission I have had.
My exposure to salt should be very limited...Sure, I am now in Florida, but I don't think I will have to worry about the salty environment since I am not driving my truck on the beach... and even then, not sure if it would be a concern. However, a couple of years ago when I was camped right on the Atlantic I did end up coming back with some salt corrosion on my camper... I think this was from the mist from the waves and wind... I don't know...
Anyway, as far as install, I am more concerned with making a mess in my rental driveway than my ability to do it. It seems pretty straight forward. I will check out the Dorman pan though. I don't guess I need that fancy PPE one... I will admit, it does look nice, but then again, no one will be crawling under my truck to check out my transmission pan! LOL
Originally Posted by honda250xtitan
i would do none of that. upgrade the shocks and steering stabilizer.
I did that a long time ago. All Bilstien!
Hello Chad... There's a reason why I have "All Stock with 270,000 miles" in my footer. I will say I do appreciate the drain plug on the transmission pan if I'm changing the transmission fluid. Enjoy your truck.
I can appreciate that, and I know that many things upgraded on these trucks aren't a necessity. However, I do enjoy doing these things, and I do believe that each little thing can improve stock performance... as to whether or not that is enough to warrant an upgrade is another question. However, regardless of upgrading the parts, I will continue to do earlier than suggested fluid changes, and in this case, a transmission pan with a drain plug will make that easier.
Anyway, thanks for all the replies. And Overkill, I am going to have to spend more time looking at the things you shared!
Old Oct 14, 2023 | 02:05 PM
  #35
Overkill2's Avatar
Overkill2
rrthor
6.7L Power Stroke Diesel
Jun 4, 2013 03:36 PM
rileyruffen
2004 - 2008 F150
Mar 4, 2011 01:28 PM
kenwowski
2004 - 2008 F150
Sep 11, 2009 12:16 AM
Trek93023
1997 - 2003 F150
27
Apr 11, 2006 05:48 AM
mzimmers
Jul 21, 2004 05:27 PM
